MaineJed Posted July 7, 2024 Posted July 7, 2024 Finally broke my outside light cover! I know they are rarer than hens teeth but does anyone know where to get a generic one that fits? Quote
MaineJed Posted July 7, 2024 Author Posted July 7, 2024 Went through some old threads and found one that a member ordered on Amazon, $14! Quote
Homer Posted July 8, 2024 Posted July 8, 2024 here is what I constructed with a piece of aluminum for mine. Mine deteriorated to nearly nothing. I took measurement and put them on card stock then cut the template out and used the pliers to bend to shape so it fit the frame and drilled a hole and added stained glass instead of solid. The top is slightly tapered. If you are sort of a handyman you can make yourself one and save $$$ . I used silicon caulk to hold the glass in place on the inside of cover, Hope this helps. Quote
mio mio Posted July 29 Posted July 29 Those enybody know where I can get the light socket for this patio light Quote
Ssunrader Posted August 2 Posted August 2 The bulb is a common 1141, uses the same socket as the even more common 1156. Should be able to find something based on that. mine works so haven’t had to take it apart. Quote
Ssunrader Posted Thursday at 01:40 PM Posted Thursday at 01:40 PM Make sure and get one that has an actual ground wire on it since the camper won’t be grounded by attaching the socket alone. Quote
V6 Seabreeze 92 Posted Friday at 05:42 AM Posted Friday at 05:42 AM I Just read the light cover post. I have the same light fixture and ordered replacement cover from this link a while back. Best !!! https://www.walmart.com/ip/Specialty-Recreation-SR33101-Replacement-Light-Lens-for-Lighted-Assist-Handle/175204032 Quote
