bigstar Posted May 19, 2024 Posted May 19, 2024 (edited) None of the marker lights on the front, back, and side of my toyota dolphin work. i did test one with a multimeter (full disclosure; first time ive ever used it.) but got nothing. also tried replacing it obviously, got nothing. where does the power come from? can anyone tell me where all the wiring for that leads to and from? i’m just not sure where to start. i appreciate any help, let me know if theres anything i can make more clear. Edited May 19, 2024 by bigstar Quote
MaineJed Posted May 19, 2024 Posted May 19, 2024 Do your running lights on the cab work? The coach marker lights run off the cab running lights Quote
MaineJed Posted May 20, 2024 Posted May 20, 2024 The rear ones may but the front ones wouldn’t be Quote
bigstar Posted May 20, 2024 Author Posted May 20, 2024 (edited) i might have used the wrong words, i’m not sure of all the terms… by marker lights i mean the red and orange lights near the roof on the front and back of the vehicle. by the running lights on the cab do you mean the headlights? the headlights do work. Edited May 20, 2024 by bigstar Quote
extech Posted May 20, 2024 Posted May 20, 2024 running lights are sometimes called parking lights. in the rear when the lights are on (park or headlights) the running lights work. in the front when in park light position, only the small lights in the bumper come on. all are on one circuit, so if the fronts don't work because of a blown fuse for example the rears won't work either Quote
linda s Posted May 21, 2024 Posted May 21, 2024 Here is a thread describing how to fix clearance lights. The ones at the top of the camper. https://toyotamotorhome.org/forums/index.php?/topic/6222-clearance-lights-supply-point/#comment-47314 It's not an easy job Linda S Quote
