mattrblack50@gmail.com Posted May 31, 2023 Share Posted May 31, 2023 Any suggestion on a transmission cooler for the 3VZE setup? Curious to what others are using and what sizes will fit? Pictures would be great too. Quote Link to comment Share on other sites More sharing options...
linda s Posted May 31, 2023 Share Posted May 31, 2023 You should know you already have one. They were standard on the V6 heavy duty trucks Linda S Quote Link to comment Share on other sites More sharing options...
mattrblack50@gmail.com Posted May 31, 2023 Author Share Posted May 31, 2023 Are you referring to the radiator cooler or another external cooler. I will have to take a closer look but I don't recall seeing anything special there. Quote Link to comment Share on other sites More sharing options...
linda s Posted May 31, 2023 Share Posted May 31, 2023 No it also has a small transmission cooler in the front of the radiator, about 6x9. Stock from factory, No longer available so I can't get the part number but here it is. Number 3 on this diagram Quote Link to comment Share on other sites More sharing options...
mattrblack50@gmail.com Posted May 31, 2023 Author Share Posted May 31, 2023 Thanks Linda. I'll have to take a closer look Quote Link to comment Share on other sites More sharing options...
