El Rito Posted January 17, 2023 Share Posted January 17, 2023 I was headed out for a road trip and my o/d light started flashing. From the research i've done it is either the Vehicle speed sensor, the ECM, or possibly low fluid. I added fluid, but that didn't fix it. Anyone had this happen? Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 17, 2023 Share Posted January 17, 2023 It is accessible with a code reader my guess shift solenoid. Quote Link to comment Share on other sites More sharing options...
thewanderlustking Posted January 17, 2023 Share Posted January 17, 2023 Post up what year and model RV you have. I haven’t seen a code reader with the right adapter for the older Toyotas, but all you need on most of them is a paper clip stuffed into the correct spots anyways. I probably have the correct manual at home for the later ones. The earlier Toyota Factory Shop Manual is a posted up on here already. Quote Link to comment Share on other sites More sharing options...
linda s Posted January 17, 2023 Share Posted January 17, 2023 Year and model is in the title. We don't use code readers. We count flashing lights on the dash. Simple, anyone can do it Linda S Quote Link to comment Share on other sites More sharing options...
