cannante Posted July 13, 2022 Posted July 13, 2022 So every once in awhile, the car will not turn over. I have been successful starting it by popping it into 1st gear when it happens... Until this afternoon I was. Rolling downhill, and it was in first, the weight/momentum of the car would keep it rolling for a bit but it wouldn't take any gas Stopped at a body shop for advice, and got back in and it started on its own. But am worried about the new development. I could hear first gear turn the motor but the engine not starting. Fuel pump and or electric wire corrosion is my best bet Planning on swapping the fuel pump and prayers. Thoughts? Quote
WME Posted July 13, 2022 Posted July 13, 2022 Bump start in 3rd or 4. To much compression in 1st and 2. A. Does your starter turn the engine over and it won't start? B. Or does the starter not work at all? A= fuel pump,,,ign coil amplifier B= starter solenoid, the contacter disc. Common on Toyotas...https://www.ebay.com/itm/294499462144?hash=item4491892c00:g:ajIAAOSwY8FheX7M B= bad battery cables...bad ground Quote
john*thomas Posted July 14, 2022 Posted July 14, 2022 I agree it's not best to bump start in 1st. That noted it could be many things. It's hard to diagnose over the internet. Fuel pump, ground, etc. I do not recommend to just start replacing things but there is a duel argument for replacing the fuel pump. 1. It could be that and 2. if it's not been changed it's going to need it at some point in the future anyway. Quote
86Dolphino Posted July 15, 2022 Posted July 15, 2022 (edited) I’m not sure if this is your problem. But my 86 dolphin wouldn’t start. I would turn the key and just get a click like a dead battery I’d keep trying for idk 5 10 min and it would finally start always. So I got to reading and found these Toyotas were wired a** backwards when it comes to the start wire from the ignition. I was on a Toyota off-road forum and found a article on changing the starter relay over to a universal ford/Chevy starter relays. It was super easy and now my rig cranks over like I’ve never seen before. Edited July 15, 2022 by 86Dolphino Quote
cannante Posted September 5, 2022 Author Posted September 5, 2022 On 7/15/2022 at 11:09 AM, 86Dolphino said: I’m not sure if this is your problem. But my 86 dolphin wouldn’t start. I would turn the key and just get a click like a dead battery I’d keep trying for idk 5 10 min and it would finally start always. So I got to reading and found these Toyotas were wired a** backwards when it comes to the start wire from the ignition. I was on a Toyota off-road forum and found a article on changing the starter relay over to a universal ford/Chevy starter relays. It was super easy and now my rig cranks over like I’ve never seen before. When you say the starter relay do you mean different than the starter engine? I'm quite a novice when it comes to car things. Quote
linda s Posted September 6, 2022 Posted September 6, 2022 Sorry no one responded. It seems your truck doesn't have a starter relay. Thread on Pirate suggests it's probably bad connections at fuse box or a bad ground at fender. Linda S Oh and did you get your door figured out? Quote
