93 toyota winnebago warrior
If your motorhome came with a microwave it was most likely mounted in the cabinet above your stove. If that cabinet has a door you probably didn't have one. If it doesn't look for a hole where the wire came through. Alternate place to put it is on top of the fridge. There should be a 110 outlet underneath the upper cabinet right next to that. Just plug it in there. You must buy straps the secure the microwave of course. Would help to see pics so I know your floor plan.
The factory microwave was above the sink, look in that cabinet.
Looking at the wiring diagram I do see an electric box between the over the sink cabinet and the over the stove one up near the top. It has wires that also go to your air conditioner. I'm pretty sure the over the stove cabinet is deeper so better to install it there. Should be easy to find that electric bow and tie it in there. Just turn your AC off for a couple minutes while you microwave stuff
 Share
