New owner 83 sunrader
11 hours ago, linda s said:
Maybe this will help. Same year truck
Toyota 22r carburetor float adjustment and check - YouTube
Thats the best youtube on it out there for sure.
So I didnt have a beer box but I did have a covid test box. Lol. I cut a strip to 9.8 mm. And I held it the correct orientation. Letting the float hang and pushing up.
The open measurement 48mm, doesnt seem to matter so much as its slightly above the bottom of the float bowl. Mine are probably resting on bottom when all the way down. I doubt they get all the way down.
I ended up tearing the gasket and actually found a carb rebuild kit locally for $50. Its a must have. Everything you will need for a long time.
I got the floats set. Just a hair low. But I am leaving it until after I smog.
I put in a new float plunger. I didnt replace the carrier piece as I couldn’t get it out. I remember now I need to use that impact driver tool.
I put in a new accelerator pump diafram. And cleaned it a few more times. The hard part is going from the top where the mounting surface is for the top hat going down into a barrel. Its a real small hole. The accelerator pump sends volume up, then back down through a real small hole into a shoot into the barrel. I tried a lot of tricks to get compressed air blowing through that hole.
Its running really smooth. I hadnt done plug wires but grabbed some last trip.
I havent checked the airgap in the distributor. Kinda like points? I did test the resistance on it and it was within specs. Need to research that later.
now that it runs so well, the idle is super high. I need to set air mixture and idle, and timing. I was just going through the fsm when my buddy showed up.
He knocked out the rear axle like nobody's business. The new one is sitting in on the springs and bolted down.
I think we used the donor u-bolts on my original leafs. I need to cut off the shock mount on one leaf spring pad and weld it to the other side for the shock.
I am using the donor sway bar and the stock sway bar links. I am going to put them in the vise and heat them and bend them 90 degrees to fit the donor sway bar.
parking cable looks fine. The original mount for the hard brake line at the frame was bolted on. The donor has no mount. Need to use my orininal mount.
proportioning valve bolts right up. One day I need to put a manual one.
I am keeping my old third member as a spare, and dreaming on building my v6 donor member with 4.88’s and positraction.
  • Replies 79
  • Created
  • Last Reply
Top Posters In This Topic
Up and running. I have a pesky misfire at idle that I can see with the timing light. I checked resistance in the distributor and its spec. Airgap in spec.
I set my timing right above 6. Putting a new coil and distributor cap on in the morning. The coil tests ok. Not great.
for my read swap, 83 4cyl to 90 v6, here is what I did
1. Need parking brake cables off my original axle
2. Will use original 3rd member. The flange for the v6 housing doesnt fit my driveline. We drilled two bolt holes
3. I am using the 90 sway bar, and I found some end links for a 2nd gen dodge diesel that will fit.
4. I am taking my original leaf spring mounts (the plate part the u-bolts bolt to), cutting them down, and welding to the bottom of the axle for shock mounts. I live right near poly performance (fab stuff), but these are in my driveway and DONT cost $45
so tired. We did a clutch too today. Did not surface the flywheel.
for missfire.  tight exhaust valve?
Its electronic. I can see it not fire with the timing light
new problem, bleeding. Lol. Cant seem to bleed the rear.
is the missfire cyclic or random?
It was cyclic.
I lit it up to town and she leveled off. The idle is finally normal at 4.5 turns out
its in smogging. Someone gross poluted so its star smog. He just called and had to set the timing. Whoops.
She got a little hot. It probably needs a fan clutch. Had autozone set one aside for pickup.
I need to get some taillights working. I have a full setup for a trailer and may just screw them to the bumper.
I think I have some flat spots on the tires. It shook like hell but leveled off. Fedex is delivering the new set as we speak.
and thats it. Get those things working, and hopefully we can hit the road.
That's what I call "a good shakedown"! 😁
Yeah my rig was running hot until I replaced the fan clutch, probably the most overlooked thing on these toys.
Gary
you were able to bleed the rear brakes?   you'll need a meter or test light for tail lights. don't count on color codes, and turn and brake lights are a seperate circuit
Yeah I came across an older post on here where you continuously told someone to put in a new master. So I just went and got one
I got a master for a 1990 V6 model also
The old one was puking its guts into the booster
I remember that about the lights. I put a trailer plug on my dads 49 and when you press the brakes the front turn signals light up
So I havent got time to address lights, but Im wondering if the relay is dead. No power to front running lights.
edit: failed smog. I guess I will be rebuilding this whole carburetor.
im never selling this thing
Edited by Lucas602
Gary
My last 84 was like that
There isnt a good test for the fan clutch. Spin it when its cold. Is it loose.
its $50 to buy one and its easy to install
fun fact, my original water pump had studs. New one had holes.
My Sunrader was getting hot for a while, and it wasn't the fan clutch. Was sure the radiator was OK cause I flushed it so thoroughly. Well, I was wrong. There was a big dead zone in the middle. Used thermal gun. Replaced it and never got hot again
did the smog shop give you a print out of the tail pipe numbers?
Yah. See attached. He said to fully rebuild the carb. I do have a kit.
Will do. I checked the fan when it was hot and it was completely loose
co2 at idleshows efficiency is down. o2 at 2.3 means missfire= fuel went in and came back out unused. =high hc. still passed though
cruis c02 is higher= more efficient.  02 very low=not much left over caused by too much fuel. co high resulted from the shortage of o2 .
can't make co2 if there isn't enough o2.  hc very high because of missfire from overly rich condition
Cool
He told me to just rebuild the carb.
I think I might put a weber on while I figure that out.
1 hour ago, Lucas602 said:
Cool
i have a weber on mine. if you can get a carb approved one with an air filter adapter you can chuck the toy one and have better performance
The hotter the engine the tighter the fan clutch becomes. Your description would indicate a bad fan clutch.
Ohhh I didnt know they made a cal approved one! $450 or so it appears.
So yeah, bad fan clutch. Bad radiator. Good call Linda.
An 83 radiator was like $320 and out of stuck. A radiator from a 92 (I picked a random year) was $160 and in stock. As well, it has a built in tranny cooler, which I have seen setup for plumbing water through to heat a tank.
The older truck has a big spout for the bottom hose that also included a port for the heater core return. The new did not, and I noticed notes for the hoses for a 92 “radiator to pipe” and “pipe to motor” so I assume its a separate piece in the newer truck?
I had got a cut to fit lower hose before and I cut the end 90 off so my hose fit.
So I dug it out if the trash and I cut that big barb off the old radiator.
We are 100 miles from portland. It heats up some. New radiator, water pump, thermostat, and full flush.
the heater wasnt getting hot and I remembered having heater control valve problems on an 87. So I bypassed it
As well, I took the thermostat out. Big improvement.
I did notice some “stuff” in the old radiator and wonder if its head gasket sealant.
The other problem, I hear some grinding when I let off the throttle, going from applying power to engine breaking.
I am curious if its that carrier on the driveline. I moved it and it felt loose. As if rubber mounted and not a bearing.
So I need to go look that up. I should now but if I navigate away from here sometimes I loose my draft (iphone 10 on chrome if the developer is watching)
 I am in portland for a bit. I could do the head gasket, but I can probably make it home fine. My dad is coming through here going south with an empty trailer if things go wrong.
The grinding is more of a concern. Gonna crawl under there when we arrive and look for heat or play. If its that carrier, maybe I can change it easily. Maybe I need to do all u-joints.
maybe someone has a shop in portland. Ha.
Last thought, these walls flex a lot. And its loud. Which doesnt bother me. But my gf.
Really dreaming about stripping it and building an exoskeleton on the inside (inoskeleton?) and spray foaming it.
I really want to do that and put a 4x4 diesel setup in.
I have a problem. Theres a pile of trucks at home waiting for me to get back and install some heads, motors etc.
Well getting ready to head home and fixing a few things. I took the top hat back off the carb and cleaned it with chemtool and in absence of a compressor I got a bottle of canned air for computers. Running much better.
It needs a full tear down. Theres a few things I suspect but need a shorter screw driver.
right now its running ok so following my rule of “if its not broke dont fix it”
Going to replace this carrier bearing this morning. They say to pull the whole drive shaft but Im gonna try leaving it in the transmission.
I am ordering parts from rock auto and looking at heater core. Im wondering what people do to add AC. Thus far, I have gotten a lot of parts from the newer series, 1990, and wondering if thats the case with AC.
Regardless, having a lot of fun and loving it. It navigates great through dt portland.
pretty sure to add ac you get the evap case and put it in .the holes for hoses and bolt holes are already there. there is a dummy box where the ac goes.
So for the 83 model, that nut is 30 mm on the flange you remove from driveline to change carrier bearing. Its easy to do and not pull the driveline off the truck.
And its 2.5 miles to ace hardware. And my electric scooter goes 5 miles. Pro-tip, just buy the socket set that will cover the range the bolt might be in.
The carrier bearing from autozone didnt fit.
at the point of giving up i beat it to death with a hammer and made it fit. I hope they will still refund me.
Noted on AC. Thank you. It appears you want your period specific setup.
So I will watch for one at the junkyards and get everything I can when I find it.
On 7/29/2022 at 9:12 PM, Lucas602 said:
Well, went to the junkyard for wheels, came home with an axle
Right on the main row was a dually utility truck. I scored the axle for $600 with 4 wheels
i am converting to 4x4 so I dont want the hubs. And there are 5 more wheels available.
anyone need any? Going back to pickup tomorrow or monday
any of those rims still exist? Sent you a message.
sorry there were only 2 and i got them
So there was one more in the bed, and a spare underneath
turds told me there were no more
They are pretty bad. Its a good business, lots of inventory and turnover. Bad customer service. Ill go grab them.
Home. Punchlist:
1. Head gasket
2. Shock Mounts on rear axle
3. Airbags for rear axle
4. Carb rebuild
5. Alignment
6. Ball joints and tie rods
7. Gas gauge and clean tank
8. Parking brake cables
9. Transmission tail-shaft
10. AC for cab.
So if I remember correctly, the pre-85 motors are a shorter block and taller head? I remember people putting the shorter block and head together.
Looking at head bolts and someone said the pre-85 bolts are 1/4” longer. They also suggest just running the post-85 bolts
I have only come up with one part number listing the actual bolts for my 83. Pioneer S1171
However the same site lists those for a 1990 22R. Amongst a whole list of cheaper options.
So do I just run normal head bolts? Do I have to replace these? Honestly I am just slapping a head gasket in. I could do a leak down test, determine where I am at. But no matter what I am going to change the gasket and just keep driving it for the moment. It has some blow by. With a proper head gasket I can test compression.
I am also curious if I can run the post 85 head.
I am not 100% sure what I want to do but kinda thinking about that LCE stroker kit and a carb legal weber, header, etc.
also still would like diesel.
The other issue, focusing on the tasks at hand
Edited by Lucas602
Non compatible engine parts
 Non-compatible parts include the cylinder head, block, pistons and many of the associated parts such as the timing chain and cover, and water and oil pumps (although the oil pump internals are the same
And the different head you could use for increased power is a 20r head.
Do you have single or double row timing chain. Double can stretch and brake, single lasts forever.
It can be changed over
Head bolts after 1985
Toyota 90105-12092
Bolt
head bolt for you
Toyota 90910-02058
Bolt
Clearly a different part number and size. I would not try to use the wrong size bolts
for something as important as a head gasket. You do have an interference engine
 If you were interested and could find one your size bolts are also the right size for a 20r head.
Also look at the dealer price. online is a little cheaper but more than affordable to get the OEM bolts
1984-1995 Toyota 9010512
don't you mean double lasts and single stretches?  switching to double on a 22 is expensive
Yes I'm backwards but since the change was done in 83 his might have come with the double.
 Lucas is a skilled salvage yard scavenger. Not expensive if you can find the parts and no major changes with his engine.
Timing belt cover and oil pump gear. And of course, the chain which will come with steel guides
These are all more reasons to just switch to a diesel.
A lot of the parts for this series are just expensive. Ive been buying stuff for the post-85.
I need to learn more about the toyota diesels. None of them seem eye catching. The 3.4 seems good but I dont think california will let me.
An OM606 would be cool and I can build to suite. I see tdi swaps.
I see a lot of 3.0 jdm diesel engines with a 5 speed manual and transfer case for $4000.
Which makes me want to just reuse my head bolts and throw a gasket in.
edit. Thanks for the part number. These guys have a set. Grumplily ordering.
https://www.lceperformance.com/20R-22R-OEM-Head-Bolt-Set-1975-1984-OEM-Toyota-P-N-p/1024077.htm
Check out this stroker kit. If you toggle through the options you can see the differences in all these years. Different main bearings for 81. Etc.
One thing I should check is I have the original engine
https://www.lceperformance.com/Street-Stroker-Kit-Without-Rods-p/1010032.htm
I also found a repair sleeve for the transmission output. It says it presses in from the outside.
Edited by Lucas602
doesn't that come out to $83?
1 hour ago, linda s said:
So please tell me. Why buy a 65 dollar head bolt set when the same is 6 bucks from Toyota. Maybe as much as 8 bucks from a local dealership
9091002058 - Bolt(for cylinder head set). Engine - Genuine Toyota Part
I can buy a set vs buying one of a single item and chancing they are all the same length.
 Share
