Old Man Smith Posted May 15, 2022 Share Posted May 15, 2022 I've got a 77 Pont-X (if you look them up, mine will be in most of the pictures), the turn signals and hazards just stopped working. Fuses seem to be OK, high beams work fine, so I don't think it's the lever switch on the column. Someone mentioned it might be some other circuit in the column, but I think it could be the relay. Any thoughts? Quote Link to comment Share on other sites More sharing options...
5Toyota Posted May 15, 2022 Share Posted May 15, 2022 if you have that big four way flasher knob on the dash. pump it on and off a few times and see if that fixes it . i am serious corrision or dirt builds up on the four way switch it normaly never gets used much. this was a problem with the 7os trucks and campers. and when this happens the turn and fourway quit working. my 78 shortbox truck my 78 motor home . i had this happen Quote Link to comment Share on other sites More sharing options...
Old Man Smith Posted May 16, 2022 Author Share Posted May 16, 2022 Thanks for the reply and tip! It ended up that I just had a wire that had come off of my flasher. Everything was/is still fully functional, just got disconnected. Learning all of this as I go and trying to get this thing back into true, reliable form again. Now I know what a flasher looks like lol. Thanks again! Quote Link to comment Share on other sites More sharing options...
