gringostar Posted May 9, 2022 Share Posted May 9, 2022 I've had blowouts on the front tire and blowouts on a rear tire. I only carry a spare for the front tire, so If I have a blowout on the rear I have to limp the RV to a tire shop and have them swap the rims. It's usually a three hour ordeal. I believe 1986 Toyota trucks carried the spare under the truck with some kind of chain and pulley. Is that still there? If not, what do I need to do? Quote Link to comment Share on other sites More sharing options...
WME Posted May 9, 2022 Share Posted May 9, 2022 If yours is missing, then go to a wrecking yard and get one from a Toyota PU, don't forget the crank. This is what it looks like...https://www.ebay.com/itm/303800308069?hash=item46bbe8d165:g:oV4AAOSwa9NfztyR If the OEM didn't bugger things up, it is a simple bolt on. Remember a security chain Quote Link to comment Share on other sites More sharing options...
fred heath Posted May 9, 2022 Share Posted May 9, 2022 Why not just carry a unmounted spare tire of the correct size. A lot less weight and no 6 lug spare wheel to deal with. Your more likely to puncture a tire than to blow it out. Quote Link to comment Share on other sites More sharing options...
