Legobusier Posted April 10, 2022 Share Posted April 10, 2022 Hi all, I noticed that the fittings on my propane hose leak, so I need to replace it. It’s 12” long and has 1/4” flare fittings (female on both ends)…I can’t seem to find one anywhere. It’s off of an ‘85 Sunraider if that matters. Here’s a photo of the hose, and the fitting it needs to attach to. Seems like it would be easy to find, but…. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
linda s Posted April 10, 2022 Share Posted April 10, 2022 Not good. Yours looks to be a no longer made auto stop valve. Best case would be to talk to propane place, ask first if they do repairs, and see if they are willing to fabricate just the hose. Tank must be completely empty to replace it. If you can find someone to do that the tank must then be purged. Pumped full of nitrogen so no oxygen is left inside. Other option is if they can cap the hole in tank hose leads to and install a modern float fill valve. Linda S The hard part is finding anyone to work on them. Quote Link to comment Share on other sites More sharing options...
linda s Posted April 10, 2022 Share Posted April 10, 2022 Here's a very informative blog post about the Auto stop fill device with pictures. As you can see it looks exactly like yours. Shows parts needed to fix the problem The Infamous Auto Stop Propane Fill Valve. | arts-attic.com Linda S Quote Link to comment Share on other sites More sharing options...
fred heath Posted April 10, 2022 Share Posted April 10, 2022 Try this place. Good selection and low prices. https://propanewarehouse.com/ Quote Link to comment Share on other sites More sharing options...
Legobusier Posted April 11, 2022 Author Share Posted April 11, 2022 Thanks guys. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted April 12, 2022 Share Posted April 12, 2022 (edited) i have removed one of those .. go to an rv supply or on line what you get is a kit which is a new plain filler neck and a new bleeder valve. did this for a guy who could not fill his tank. just do job outside only fumes out of his empty tank were terable. maybe a large gas supply plant could supply the hose do you have an rv s hop near you. i just bought a new hose for my new furance. i see the filler neck listed on that site tank filler neck .a lso the liqued level bleeder valve. Edited April 12, 2022 by 5Toyota Quote Link to comment Share on other sites More sharing options...
5Toyota Posted April 12, 2022 Share Posted April 12, 2022 my freand had this on a large type class C 20 gallon tank Quote Link to comment Share on other sites More sharing options...
Legobusier Posted April 14, 2022 Author Share Posted April 14, 2022 I was able to find a suitable stainless steel flexible tube at a local propane shop. Fill valve/assembly still works as designed, my issue was simply a bad hose. Took it back there today for a proper purge and fill....all is back to normal. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
