thewanderlustking Posted January 6, 2022 Share Posted January 6, 2022 Finally got my check engine light working... I got a code 11 now that the light flashes. But timing doesn't appear to ever "lock." Will it throw 11 if the TPS is adjusted wrong and the engine is on/running without the TPS in the closed position? And does the timing lock at 5 if the TPS is not correctly adjusted? With mine hot and running, a blip of the throttle sent it moving right along. At work, I found some docs/repair reports saying to time it to 15 degrees without the jumper. I snagged this from the LCEgineering timing article. Can anyone verify that the far left pointer/mark is 15? Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 7, 2022 Share Posted January 7, 2022 On 1/5/2022 at 7:49 PM, thewanderlustking said: Finally got my check engine light working... I got a code 11 now that the light flashes. But timing doesn't appear to ever "lock." Will it throw 11 if the TPS is adjusted wrong and the engine is on/running without the TPS in the closed position? And does the timing lock at 5 if the TPS is not correctly adjusted? With mine hot and running, a blip of the throttle sent it moving right along. At work, I found some docs/repair reports saying to time it to 15 degrees without the jumper. I snagged this from the LCEgineering timing article. Can anyone verify that the far left pointer/mark is 15? Because the pully turns clockwise I would say that is correct. Quote Link to comment Share on other sites More sharing options...
extech Posted January 25, 2022 Share Posted January 25, 2022 the computer makes adjustments based on the timing being set with the idle switch closed. if the timing marks are moving around, the computer is attempting to get the timing where it needs to be. grab the throttle and turn it towards closed. you should see the marks stop moving. usually the adjustment is off because of build up around the throttle plate. it needs to be cleaned. Quote Link to comment Share on other sites More sharing options...
extech Posted January 25, 2022 Share Posted January 25, 2022 11 code is switch circuit. most likely a/c switch, tps, or ecu Quote Link to comment Share on other sites More sharing options...
thewanderlustking Posted January 25, 2022 Author Share Posted January 25, 2022 Apparently if the TPS needs adjustment and isn't going to the off/idle position, it will set this code. I don't know how smart this pre-obd system is and how to turn that code off or clear it. Or what conditions it clears itself under. But it was defiantly out of adjustment. AC compressor is removed. So depending on what the AC switch is, this could also be the cause. If it is a low pressure switch, removing the AC compressor would obviously activate this. It could be amusing to pursue a little bit more to sort out, but I have other more entertaining jobs to tackle. With the TPS correctly adjusted I was able to lock the timing. There is a much simpler procedure I was taught on the Yotatech Forum by Jimkola than using a multimeter. You remove the throttle body and loosen both TPS screws. Put it back on, loosely tighten the top screw. (You can't get to the bottom screw safetly with the throttle body on. And use QUALITY screwdrivers to break them free, they are usually stuck good.) Start the truck/car up get to operating temp. Insert jumper. Rotate the TPS and watch timing. You will see it stabilize, rotate until it jumps, then turn it back ever so slightly until it stabilizes again. It is a noticeable difference. Lock the top screw down snuggly. Shut down, pull the throttle body back off and tighten the bottom screw. I would add that you probably should replace the throttle body gasket. Mine tore but I left it alone and put the TB back on. No sealing issues. A thin smear of RTV would reseal it well enough too until you could get a new gasket in hand. So I was able to get my timing locked in and sorted out. It was almost 40 degrees advanced!!!!!!!!!! And the engine still pureed happily like nothing was wrong. Crazy. I think without the jumper, rest timing was at 15 degrees. With the timing locked it is set per the sticker on the hood. I think mine said 8 but I would have to verify. It was a couple weeks ago now. Quote Link to comment Share on other sites More sharing options...
