Ctgriffi Posted October 4, 2021 Share Posted October 4, 2021 (edited) In the past, I've noticed quite a bit of heat coming off the transmission tunnel and across the whole cab floor in general. So, last month, prior to heading to the Deep South on our biggest excursion of the year, I decided to pull up the original gray vinyl stuff in the cab and add some more heat/sound insulation. (I was surprised by how little was in that area from the factory... pretty bare bones setup under there!) I went with a single roll (36 sq.ft.) of this Siless 157 mil product and a roller, plus some foil tape for the seams. The Siless stuff is like a big, rolled-up sheet of weather-stripping and not the easiest thing to work with, although it does cut nicely with scissors. It basically cannot be repositioned once it touches the surface, due to some very strong adhesive, so I found it worked best to cut roughly 12" x 12" squares and piece them closely together, rolling every inch firmly into the underlying sheet metal, and taping the seams. I splurged and did double-thicknesses all over the tunnel, too. I also ripped out the last scrap of the original, filthy "Pine Mist" carpet that lined the back of the cab and replaced with new, gray low-pile stuff. Very happy with that update. We just returned from our trip and, while the sound dampening improvement is hard to distinguish, the insulation made a huge difference in terms of heat coming off the floor: it's just slightly warm to the touch now, where it used to be surprisingly hot. Wish I'd had an infrared gun to measure the difference, before and after, cause it's very significant. Insulation Installed - Before Taping Finishing Up Install Tip: If you've never had the seats out, you'd better hit those bolts first with plenty of PB Blaster and/or use a torch on them from underneath the truck. Edited October 4, 2021 by Ctgriffi Quote Link to comment Share on other sites More sharing options...
Scott iv Posted October 4, 2021 Share Posted October 4, 2021 That looks nice. I have plush tan factory carpet in mine that needs to go. I can see my seat bolts are rusty so I've been postponing that project. Quote Link to comment Share on other sites More sharing options...
Maineah Posted October 4, 2021 Share Posted October 4, 2021 Yeah it works I did the same to my Tacoma a couple of years ago not some much for the heat as the noise level. Quote Link to comment Share on other sites More sharing options...
TinMan-Scarecrow-Dolphin Posted June 8, 2022 Share Posted June 8, 2022 I have already removed my passenger seat, overall in very good condition even if half it's 38 years....except for the underside. The springs have disinterested, leaving only their oxidized stained imprint in the foam, otherwise I wouldn't be able to say for certain what should be there🤔 Quote Link to comment Share on other sites More sharing options...
linda s Posted June 8, 2022 Share Posted June 8, 2022 Auto upholstery usually uses zig zag springs like this They are not expensive and you just cut to fit and reinstall if your connecters are still sound. If connecters have rusted out you may be able to reinstall new ones. All the work can be done from the bottom so no need to remove fabric. Add new foam before you replace springs. Probably be easier to find some decent seats at a salvage yard. People have used seats from 4runners, Camrys, Kias and few a other vehicles Linda S Quote Link to comment Share on other sites More sharing options...
