Replacing holding tank valves in 1987 Sunrader
Iflyfish
My drain valves need to be replaced. Does anyone know off hand what size valves I need. It looks like one is 3 inches. Thank you.
Poopy valve is 3 inches and gray water valve is 1 1/2 inches.
Yours don't look that old. You know they can be repaired
rv waste valve seal kit - Google Search
It's good to lubricate them from time to time too. At the dump when you can push them in and out spray with wd40 and in and out them a few times. Makes them easier to use and last longer
Great! Thank you very much!
Thank you very much! I really appreciate your work! I wonder if there is a way for me to get notifications for all posts? I used to get them. Thanks
