1987 Dolphin House Battery
Plain Jane
 Share
Hello all,
I bought my 1987 Dolphin with everything including manuals EXCEPT the original house battery AND, curiously, the battery manual. So not sure what specs a replacement battery should have. Could anyone help with this?
Thanks in advance,
PJ
You need either a 24 or 27 size deep cycle battery. Find where it goes and measure to see what will fit. There are online measurements for batteries that you can look up. Just make sure the one you buy is a deep cycle. Hopefully you can find someone to help you who is not too stupid. I use the standard flooded acid type. They are the cheapest and mine have always lasted 5 years or more. Gel type is supposed to be better but I have changed out at least 6 Optimum batteries for friends and they were not old at all. Lithium batteries will cost you more than your Dolphin did. Some here have gotten high amp hours , time you can use stuff before power is gone, by connecting 2 golf cart batteries. I'll let them explain
24 and 27 batteries are 12 v.
In case you like pictures... here's a basic, inexpensive Group 27 deep cycle that lots of folks use (and no, they are not fun to carry!).
  • 4 weeks later...
Sooo, here I am on the Dolphin's first camping trip to test all systems. Plugged the brand-new plug into the campsite power in the receptacle that took it and ... nothing. It's still a lovely night and don't need the AC, so have given up for the night, but ... WTF?
When you plug in at the power hookup Box at campgrounds Often the power switches are at OFF position. Just flip them to ON. Could be a simple fix.
2 hours ago, Plain Jane said:
Power worked fine off the truck battery - all the lights came on when I started the engine. Have combed the manual and can't find out where the fuses are located.
Your fuse box for the camper is somewhere near the floor. A square or rectangle metal door with  vents. Open it and you will see all the fuses. Here's a pic from a Dolphin
Did your interior lights ever work when the truck wasn't running. Is the coach battery new? Check the coach battery with a multimeter with the truck off. Should be showing at least 12.6 if fully charged. Below 12 and your battery is already sustaining some damage. Below 11.3 and it's dead and you need a new one. If it's not too bad check voltage again with truck running. Should be 13.7 to 14.7.
If battery tests OK then something else is hooked up wrong and the power is not getting to the coach. Fuses are probably not the issue because if they were bad it wouldn't work with truck running either.
Linda
Thanks all. It turns out the campsite power was delivering just fine, which I discovered when I touched the ends of the wires that are supposed to go into fuses and felt a brief tingle (yeah, I know, not a smart thing to do). I have two switches which I guess are supposed to be the terminals for those wires, but that's too advanced for me - I'll have to get the skoolie guy back do that. @Linda, I don't know if anything runs with the truck turned off - this trip is my chance to test everything.
I've booked the site for another night because I'm determined to check everything I can. I'll need to get a multimeter today to see what's up with the battery.
A lot of the older converters (120vac to 12vdc) have a relay to switch things around between shore power and house power. Very common after all these years for a set of dirty contacts to mess things up.  Emergency fix give the relay a wack with a screw driver handle.
The AC and the lights have nothing to do with each other. Most small RV's have 3 breakers that look like the ones in the house a 30 (main breaker for every thing then a 15 for outlets and a 20 amp for the AC. They should be easy to spot. There are two systems lights, radio, water pump maybe a vent fan. Outlets, AC and charging systems require you to be plugged in. One of the simplest gadgets you can buy is a plug in outlet tester most hardware stores will have them like 5 bucks I leave mine plugged all the time it will also tell you if the camp ground is properly wired!
 Share
