Verdmont Posted July 25, 2021 Share Posted July 25, 2021 I'm looking to trade my labor for a toyota Sunland express camper. My wife and I are looking for a project to restore but while inspecting the camper 22re engine I noticed an antifreeze leak on the front of the engine. I know this is vague and I'll admit I'm no pro when it comes to this engine but any help or knowledge would be greatly appreciated. Basically I'm willing to do the work but am just looking for any ideas as to why the engine would be leaking antifreeze. Thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
linda s Posted July 25, 2021 Share Posted July 25, 2021 There's a hose on the drivers side kind of behind the alternator that goes from engine to engine. It's a coolant hose. Lots of people don't even know it's there. Might be the leak spot. Linda S Quote Link to comment Share on other sites More sharing options...
fred heath Posted July 25, 2021 Share Posted July 25, 2021 You May have a bad water pump. Most pumps are designed with a “weep hole” which allows a small amount of antifreeze to leak out when bearings are failing. The22r water pump is attached to the front of the engine. Do you hear any grinding sound when engine is running? I’d check that out first. Quote Link to comment Share on other sites More sharing options...
Scott iv Posted July 25, 2021 Share Posted July 25, 2021 Yea, you'll want to track down that leak. There are quite a number of coolant hose locations on the 22re. The coolant is under pressure and can spray. If you discover it is a hose leak, consider changing all the coolant hoses to prevent continues hose failures. The water pump could be leaking through the weep hole or gasket. Not a difficult fix replacing water pump and hoses if you've done some mechanical work. Radiator cap, overflow tank. If the vehicle is new to you you'll want to inspect your cooling system thoroughly anyway as overheating leaves you stranded and leads to other problems. A number of websites have mechanical repair forums for the 22re in addition to this site. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted August 4, 2021 Share Posted August 4, 2021 rock fan check for lose or slop in the water pump Quote Link to comment Share on other sites More sharing options...
