twodog Posted May 21, 2021 Share Posted May 21, 2021 I recently purchased a 91 warrior that had been sitting for a good while. Dash lights don't work, also Tail lights don't work neither do brake lights and clearance lights. I checked fuse panel, and I am getting voltage to everything. I replaced tail light fuse as a precaution, but still no lights Any suggestions??? Quote Link to comment Share on other sites More sharing options...
linda s Posted May 21, 2021 Share Posted May 21, 2021 Try replacing your tail light relay. It can affect dash and other lights too. Most auto parts stores should have it 1980-1994 Toyota Pickup Tail Light Relay - Body Electrical - Standard Motor Products 80-94 Pickup Tail Light Relay - 8111-07681191 - PartsGeek In the kick panel with the fuses Linda S Quote Link to comment Share on other sites More sharing options...
twodog Posted May 24, 2021 Author Share Posted May 24, 2021 I replaced tail light relay. Still no lights. I've ordered all new marker lights, since covers are gone from half of them. I'm hoping the problem is in marker lights. Quote Link to comment Share on other sites More sharing options...
fred heath Posted May 24, 2021 Share Posted May 24, 2021 Sounds like a bad ground(s). Clean all grounds and see if that helps. Quote Link to comment Share on other sites More sharing options...
