MaineJed Posted January 27, 2021 Share Posted January 27, 2021 Thinking of installing an outdoor shower on my 93 Dolphin. The installation isn’t the question it’s more of where is the best place to put it, any ideas... Quote Link to comment Share on other sites More sharing options...
linda s Posted January 27, 2021 Share Posted January 27, 2021 Your going to need to attach water lines to your hot and cold water pipes. Best to find somewhere you can easily get to them that is close to an empty area on your outside wall. The shorter you have to run them the better Linda S Quote Link to comment Share on other sites More sharing options...
MaineJed Posted January 27, 2021 Author Share Posted January 27, 2021 3 hours ago, linda s said: Your going to need to attach water lines to your hot and cold water pipes. Best to find somewhere you can easily get to them that is close to an empty area on your outside wall. The shorter you have to run them the better Linda S I'm thinking of putting it on on the back side of under the sink, not sure if being that close to the water heater and furnace will be an issue if we get to splash around too much. I could put it out behind like over the right side taillight. Quote Link to comment Share on other sites More sharing options...
linda s Posted January 28, 2021 Share Posted January 28, 2021 We drive through heavy rains with water coming up everywhere. Doesn't seem to impact the water heater and furnace much. Unless you were deliberately aiming at the vents I'm sure you would be fine. Linda S Quote Link to comment Share on other sites More sharing options...
