MorboTheDMVclerk-DestroyerofDays Posted January 4, 2021 Share Posted January 4, 2021 (edited) I tried regular liquid nails but that didn't work and then I switched locktite x3. Is there a different glue for the roof and, for those of you that have the corrugated fiberglass on the sides, what do you use for that? looks like it was originally spray glue. Edited January 4, 2021 by MorboTheDMVclerk-DestroyerofDays Quote Link to comment Share on other sites More sharing options...
JaySam Posted January 10, 2021 Share Posted January 10, 2021 I've been using Gorilla Glue's version of liquid nails, Gorilla Construction Adhesive Ultimate and it's been working well holding everything together. The only thing I found that seems to bond wood to the fiberglass shell securely. Quote Link to comment Share on other sites More sharing options...
MaineJed Posted January 10, 2021 Share Posted January 10, 2021 PL glue works the best Quote Link to comment Share on other sites More sharing options...
MorboTheDMVclerk-DestroyerofDays Posted January 10, 2021 Author Share Posted January 10, 2021 11 minutes ago, MaineJed said: PL glue works the best That's what I've been using to glue luan to the aluminum frame. Quote Link to comment Share on other sites More sharing options...
MorboTheDMVclerk-DestroyerofDays Posted January 17, 2021 Author Share Posted January 17, 2021 On 1/10/2021 at 10:48 AM, JaySam said: I've been using Gorilla Glue's version of liquid nails, Gorilla Construction Adhesive Ultimate and it's been working well holding everything together. The only thing I found that seems to bond wood to the fiberglass shell securely. how fast does the tack take hold? or how do you get the fiberglass to stay pushed against the wood long enough for it to dry? Quote Link to comment Share on other sites More sharing options...
JaySam Posted January 17, 2021 Share Posted January 17, 2021 It's an instant grab type of glue, I literally just push the furring strip against the fiberglass and hold it there for a few seconds and it stays in place. For the ceiling I used braces to hold things up but on the sidewalls just pressed the wood strip against the wall. Quote Link to comment Share on other sites More sharing options...
