Ajsurf1 Posted September 27, 2020 Share Posted September 27, 2020 So the grey water keeps coming up through the bathroom drain after I do dishes in my 85 Toyota Dolphin. I just emptied the waste tanks 2 days ago and it doesn't seem like it should be full already. Is there any reason why it should be coming up the bathroom drain? Thanks, AJ Quote Link to comment Share on other sites More sharing options...
WME Posted September 28, 2020 Share Posted September 28, 2020 Make sure you are some place where you can dump your holding several times. Dump the tank, get a gallon jug. Fill it and pour it down the sink. Do this until the tank overflows. Now you know how much the tank REALLY holds. Usually some where around 12-14 gallons Dish wash drill. Use the biggest pot you cooked with, fill with hot soapy water. Wash every thing in that pot. Scrub the pot and fill with rinse water, rinse everything else. Doing dishes home style, filling a sink and running rinse water, uses a lot of water. Navy style showers are also a must. Quote Link to comment Share on other sites More sharing options...
