gringostar Posted September 4, 2020 Share Posted September 4, 2020 Hi I'm camping. The RV is about 10% tilted. I found these levelers in the RV side compartment. There are four of them. Where should I put them? Do I need to jack up the rig first? They have a twisty thing. See photo. Quote Link to comment Share on other sites More sharing options...
Maineah Posted September 5, 2020 Share Posted September 5, 2020 If they will fit under the frame that's where you 'll need them. They should not raise the MH off the ground but enough to take the load off the suspension that should level it enough for you. Quote Link to comment Share on other sites More sharing options...
gringostar Posted September 5, 2020 Author Share Posted September 5, 2020 1 hour ago, Maineah said: If they will fit under the frame that's where you 'll need them. They should not raise the MH off the ground but enough to take the load off the suspension that should level it enough for you. 1 hour ago, Maineah said: If they will fit under the frame that's where you 'll need them. They should not raise the MH off the ground but enough to take the load off the suspension that should level it enough for you. Do I need to jack up the RV first? Quote Link to comment Share on other sites More sharing options...
linda s Posted September 5, 2020 Share Posted September 5, 2020 I have always used these to level my camper. The twisty thing is strong enough to lift the coach easily as long as you remove your soccer team first. Sometimes I only used them on my bumper, sometimes the frame. Depends on where it's low. In extreme unlevel spots they might not be enough. I move the camper to get to the most level spot. In the wilderness big flat rocks and the occasional tree branch have helped Linda S Quote Link to comment Share on other sites More sharing options...
