Iflyfish Posted July 14, 2020 Share Posted July 14, 2020 I just hired these Gomobile to replace my six tires on my '87 Sunrader. New tires, balanced, filled with nitrogen and installed $675! Just wanted to let people know this is an option, at least here in Oregon. Iflyfishwithtires Quote Link to comment Share on other sites More sharing options...
linda s Posted July 14, 2020 Share Posted July 14, 2020 What kind of tires and will they give you the date code to see how new they are Linda S Quote Link to comment Share on other sites More sharing options...
Iflyfish Posted July 16, 2020 Author Share Posted July 16, 2020 On 7/14/2020 at 4:50 PM, linda s said: What kind of tires and will they give you the date code to see how new they are Linda S Brand new Nexen Roadian Tires https://www.amazon.com/s?k=nexen+roadian&ref=nb_sb_noss Quote Link to comment Share on other sites More sharing options...
linda s Posted July 16, 2020 Share Posted July 16, 2020 The only Nexen tires that would fit our vehicles is the Roadian CT8. That tire has been discontinued in the size we need for a while so a date code is a must. Be careful they don't try to stick you with a non D load tire Linda S Quote Link to comment Share on other sites More sharing options...
Iflyfish Posted July 16, 2020 Author Share Posted July 16, 2020 15 hours ago, linda s said: The only Nexen tires that would fit our vehicles is the Roadian CT8. That tire has been discontinued in the size we need for a while so a date code is a must. Be careful they don't try to stick you with a non D load tire Linda S Thanks Linda, I appreciate your due diligence. Roadian ct8 8ply load range D. They have 499+ available in their warehouse. Quote Link to comment Share on other sites More sharing options...
linda s Posted July 17, 2020 Share Posted July 17, 2020 Wow that's an awful lot of rarely used tires to stock up on. Sounds like your getting a great deal Linda S Quote Link to comment Share on other sites More sharing options...
Iflyfish Posted July 17, 2020 Author Share Posted July 17, 2020 20 hours ago, linda s said: Wow that's an awful lot of rarely used tires to stock up on. Sounds like your getting a great deal Linda S They have warehoused tires to support their national franchises. This is a relatively new business model. Great people to work with. They are also installing my tire pressure/temp monitor. https://www.amazon.com/gp/product/B07R6H6T37/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 and my valve extender https://www.amazon.com/gp/product/B084LC3ZH5/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 There is a small flange that needs to be attached to an axle to attach the extenders. Quote Link to comment Share on other sites More sharing options...
linda s Posted July 18, 2020 Share Posted July 18, 2020 Well your getting an even better deal with all those ad ons. Chances of there being a franchise anywhere near me are slim. Nearest city, Redding is almost 3 hours away. The good part is the whole county has had only 175 cases of covid19. Linda S Quote Link to comment Share on other sites More sharing options...
Iflyfish Posted July 19, 2020 Author Share Posted July 19, 2020 On 7/17/2020 at 6:17 PM, linda s said: Well your getting an even better deal with all those ad ons. Chances of there being a franchise anywhere near me are slim. Nearest city, Redding is almost 3 hours away. The good part is the whole county has had only 175 cases of covid19. Linda S Stay safe! Quote Link to comment Share on other sites More sharing options...
V6 Seabreeze 92 Posted July 19, 2020 Share Posted July 19, 2020 Hi Iflyfish I have to admit I did not know of this Pressure /Temperature monitor until I read your post. It sounds like a must have gadget. Could you please write more about this. It appears the sensors are in the valve stem Cap. I guess they can be removed in case one of them malfunctions. You also mentioned they were installed by your tire shop. Where is this place in Oregon? I am in Gresham, Oregon closer to Mt. Hood. You said tires are filled with nitrogen, is that necessary with these sensors? A while back one inside tire went flat, Valve stem was too old and leaked air. By the time i noticed it had sheared off couple of Lugs. Luckily nothing happened on the road. I see this monitor will tell you when something happens with tires. Do you have any photos to share what they look like when installed. Thank you. Looking forward. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted July 19, 2020 Share Posted July 19, 2020 6 hours ago, V6 Seabreeze 92 said: You said tires are filled with nitrogen, is that necessary with these sensors? IMHO, no. Quote Link to comment Share on other sites More sharing options...
Iflyfish Posted July 19, 2020 Author Share Posted July 19, 2020 13 hours ago, V6 Seabreeze 92 said: Hi Iflyfish I have to admit I did not know of this Pressure /Temperature monitor until I read your post. It sounds like a must have gadget. Could you please write more about this. It appears the sensors are in the valve stem Cap. I guess they can be removed in case one of them malfunctions. You also mentioned they were installed by your tire shop. Where is this place in Oregon? I am in Gresham, Oregon closer to Mt. Hood. You said tires are filled with nitrogen, is that necessary with these sensors? A while back one inside tire went flat, Valve stem was too old and leaked air. By the time i noticed it had sheared off couple of Lugs. Luckily nothing happened on the road. I see this monitor will tell you when something happens with tires. Do you have any photos to share what they look like when installed. Thank you. Looking forward. Here is the link to Amazon where I purchased the monitor. https://www.amazon.com/gp/product/B07R6H6T37/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 The sensors are attached to the valve stems. There are 190 + 4 star reviews of the monitor. I put valve extenders on the interior rear tires to ease install and tire filling. https://www.amazon.com/gp/product/B084LC3ZH5/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 The tires are filled with Nitrogen but that is not necessary for the sensors. I had a Mercedes powered Winnebago View and blew an inside tire on a two lane road in Oakland California with cement barriers on each side. I vowed to never have that experience again! I purchased one of the early made units for about $375. This is the company truck in my driveway. GOMOBILE 971 533 0050. They are the real deal, honest and great to work with. Let them know I referred you please. Iflyfishwithnewtires Quote Link to comment Share on other sites More sharing options...
cannante Posted February 18, 2021 Share Posted February 18, 2021 On 7/14/2020 at 7:50 PM, linda s said: What kind of tires and will they give you the date code to see how new they are Linda can you confirm that 14 inch tires are what is needed? Because the only ones that they have are 16 inch in an 8 ply Quote Link to comment Share on other sites More sharing options...
linda s Posted February 18, 2021 Share Posted February 18, 2021 The size is 185r14 with no middle aspect ratio. Here are some examples if they try to tell you they don't exist. 185-Blank-14 Tires | Tires-easy.com (tires-easy.com) Linda S Quote Link to comment Share on other sites More sharing options...
Nam Posted February 24, 2021 Share Posted February 24, 2021 great deals. I did have similar PTMS installed 3 years ago. It works great and give me a piece of mind. Mine also has temp. display. Only down side is batt. needs repl. every 1.5 - 2 yr. cheap and easy compared to those OEM internal TPMS sensors Quote Link to comment Share on other sites More sharing options...
