Hello, I have a 1983 Toyota Huntsman (20 ft) with the original 5 lug nut axle and I am looking to get it replaced. I am calling around scrap yards to find a replacement and I just want to make sure I know what to ask for. What I've gathered from talking to a couple mechanics is that I need a full floating axle from a 3/4 or 1 ton (1 ton better) Toyota with a 4/10 gear ratio. Also need the deferential and the drive shaft.
Correct? Any other specification I should ask for?
Thanks!
-Ruby
Where are you located?  I don't suppose you are any where near Georgia?  Cause this one is available:
https://atlanta.craigslist.org/atl/pts/d/lithia-springs-1987-toyota-rv-parting/6984285844.html
You can find a decent used 4.1 3rd member pretty easily if your axle doesn't come with one.  This is the one available at that link above and will give you an idea of all of the "extras" that ideally would come with a used axle (this one has the drive shaft available too and I'm pretty sure it's a 4.1):
  • 3 weeks later...
