john lindy Posted November 1, 2019 Share Posted November 1, 2019 main propane gas regulator leaks gas like to know where to order a new one or if it can be repaired Quote Link to comment Share on other sites More sharing options...
linda s Posted November 1, 2019 Share Posted November 1, 2019 You just replace it. They are not expensive. A local RV shop or dozens of places online will have them. Amazon, Ebay, Camping World. You need to make sure you buy the correct one, vertical or horizontal so the vent is facing down. You also need yellow gas tape. Like plumbers tape but for gas lines. Gas goop is also a good idea. Check carefully after installing with soapy water to make sure it doesn't leak, aka bubble, anywhere Threads from tank to regulator should be left hand thread too. Linda S Quote Link to comment Share on other sites More sharing options...
