On 9/4/2020 at 2:33 PM, linda s said:
Some of the parts listed you probably don't need. The wheel stud and stud nut are  to put your tires on.  Not part of brake job. Also the listing for acorn is the axle bolt. Those are probably ok too the Toyota part right under that is the acorn nut that you will need to replace. Most people don't replace wheel cylinders if they are not leaking but in this case with any work being such an extensive job replace them for good measure. Remember there are 2 sides here so order enough for both sides, 2 each of seal , etc. Oh and all the rest is fine. Just like the shoes I posted way better
For all these parts work on my 86th dolphin Seabreeze
  • 4 months later...
  • Replies 118
  • Created
  • Last Reply
Top Posters In This Topic
An invaluable list. Thank you.
I do have a related question. I have an 84 dolphin, previous owner had the rear axle recall performed so good to go there. I obtained the front hubs from an 87 so I only have to carry 1 spare. the calipers are hanging me up, tho. I ordered 2wd 1-ton calipers w/ brackets for an 88, but they seem to not reach the spindle. I didn't physically test this, I just looked at the size difference between the new and old one. the new one seems much shorter. Am I missing something? Like maybe the arc is different? It should be a 5mm difference, yes?
here you can see the differences
one on the left is  1/2 ton. the other is 1 ton
Appreciate everybody that chimmed in and added their grain of sand for us newbies working on these great machines.
Our shop, Tampa Cruisers, recently took the -gamble- of working on a 1992 Seabreeze for one of our customers. It's been a joy and a great learning experience!n
We just finished brakes, bearings, seals, Bilstein shocks in all 4 corners; moving to sway bar bushings and leaf bushings as well. Working on the best choice in steering dampener (Checking if Old Man Emu or Dobinsons have an offering since We're dealer of their products).
We replaced the AC Condenser, compressor, evaporator and fuel filter previously.
Thanks for all the parts help and guidance.
If anybody ever needs help with their Toyota RV in Florida, or beyond, We're proud to say We work in not only Land Cruisers, but Toyota Rv's as well.
Manny @ @TampaCruisers
  • defrag4 changed the title to Toyota Motorhome part numbers for Brakes, Axles, Suspension, etc
On 10/4/2025 at 4:24 PM, TampaCruisers said:
nice work Manny!
iirc I could only track down 2 steering dampers that fit, one was from Monroe and the other from Skyjacker
check
Monroe SC2914
or
Skyjacker 7186
Anyone know how to tell the difference between a 1/2 ton and 1 ton Brake Master Cylinder? My 1986 Toyota SunRader has a Recall 1 ton Full Floater Rear End installed by Toyota. I am rebuilding the front end with a 1 ton. The Master Cylinder looks like the 1 ton photos. Is there anyway to tell visually? Thanks in advance.
1 ton bore 15/16  1/2 ton 13/16
Can I figure it out without taking it off? Where to I measure? Thanks.
Edited by RaderDog
have to pull it from thebooster and measure the the piston bore
Damn. Ok. Thanks.
