Propane extend-a-stay
Homer
I was wondering if you screw the end of the extend-a-stay into the fitting under the yellow FILL cap. or do you have to take the lines loose and add the kit and hook back up in order to use an extra 20 lb when you run out of propane?  I have never seen one in action and no one around here knows anything about one.
The extenda stay goes between the shut off valve and the regulator. The adda tank feeds high pressure propane to the system.
Thank You Derek and WME. I got my answer and I was completely wrong. Thanks for both of your HELP !
learned something new. that's pretty cool wouldn't mind one for my little grill. It takes those dang 1lb tanks. it would be nice to just plug it in and use it. one less thing to get.
