neubie Posted August 24, 2018 Share Posted August 24, 2018 (edited) Anyone know if any of the dealers can service ye olde motorhomes? Just been told no-can-do-lift-not-big a couple times. edit -- just to emphasize, in the area of the bay de san francisco. Edited August 24, 2018 by neubie Quote Link to post Share on other sites
linda s Posted August 24, 2018 Share Posted August 24, 2018 Your entire motorhome weighs less than a Ford F250. Just ask if they can work on one of those. Why would you pay the big bucks for a dealer. There's a repair shop on Winchester called" Made in Japan" Seem to be rated pretty high and have tall shop doors. Make it clear your motorhome doesn't weigh more than a Tundra. Linda S Quote Link to post Share on other sites
Derek up North Posted August 24, 2018 Share Posted August 24, 2018 Before they get a chance to say they don't do motorhomes, be sure to tell them your 'pickup' only weighs 6000lb. ? Quote Link to post Share on other sites
neubie Posted August 25, 2018 Author Share Posted August 25, 2018 Derek, the appointment ladies have had no general clue despite being told its just a van sized vehicle. They put me on hold and went and asked someone and came back with a negative "take it to rv mechanic" answer. Its probably the wrong answer without a basis, but how do you get your foot in the door with that attitude at the other end. Quote Link to post Share on other sites
neubie Posted August 25, 2018 Author Share Posted August 25, 2018 37 minutes ago, linda s said: Your entire motorhome weighs less than a Ford F250. Just ask if they can work on one of those. Why would you pay the big bucks for a dealer. There's a repair shop on Winchester called" Made in Japan" Seem to be rated pretty high and have tall shop doors. Make it clear your motorhome doesn't weigh more than a Tundra. Linda S Made In Japan is quite near. Will ask them next time I drive by. Quote Link to post Share on other sites
Squirrel Posted August 25, 2018 Share Posted August 25, 2018 I've come across this issue before. It isn't because of the weight of the vehicle, so much as the height. Most shops have fancy lifts that put a car or truck over head height for easy access to parts. They just don't want to crawl underneath. You have better luck with smaller shops that absolutely need the work. Quote Link to post Share on other sites
fred heath Posted August 25, 2018 Share Posted August 25, 2018 Find a shop that works on heavy trucks. Their lifts will easily accommodate your Toyota. Quote Link to post Share on other sites
Derek up North Posted August 25, 2018 Share Posted August 25, 2018 Back to basics: what work do you want done that would require a Dealer for big $$$$? Quote Link to post Share on other sites
Vanman Posted August 25, 2018 Share Posted August 25, 2018 (edited) Well if you are willing to pay dealer prices Toyota of San Francisco on Geary St did all of the rear brake, flush everything, all hoses, mount tires replace valve stems for me. They replaced the thermostat cover and thermostat said it was leaking. I called the man on that cause I never saw any leaks and he showed me the crack in the thermostat cover, which I did keep as a spare. Glad he got that. It isn't because of the weight of the vehicle, so much as the height, yes the Les Schawb around here won't take the RV, I went to the one in Fairfield. Edited August 25, 2018 by Vanman Quote Link to post Share on other sites
neubie Posted August 25, 2018 Author Share Posted August 25, 2018 Derek, Vanman, Vanman -- what did they charge you total, do you remember? There is no known work needed except an oil change. But, and this js a big .... butt...., it does need a thorough mechanical going over to give me some confidence in engine+transmission. Has never had anyone who knew what they were doing look it over yet. Just draining the oil and refilling will keep me uncomfortable about getting stranded. Since I dont know any mechanics here, I figured the dealer is the next best thing. It will take me years to get sufficient knowledge to maintain the truck part starting from absolute zero, current illiterate status. The fluid levels are fine, no hoses are loose, no lights that should be off are on and those that should be on are off, it starts and runs. Thats the extent of my abilities. I have degreased it some and would like the sort of thing vanman got done. As needed of course. May be a local mechanic would be just fine, buy a LCE hose kit for good measure, take it to someone like Made in Japan that Linda mentioned and have them do a fluid change and hoses. Quote Link to post Share on other sites
Vanman Posted August 26, 2018 Share Posted August 26, 2018 Several thousand dollars, would have to dig up paperwork, they checked everything including a compression check and look at plugs, very important, if you cannot read spark plugs find someone who can... BUT first you should read all the top posts in this board, takes a long time I know, but you will learn much about your new toy before spending any money. Plan ahead always!! This stupid new imac black on black keyboard is driving me nuts more typos than text!!! Quote Link to post Share on other sites
neubie Posted August 26, 2018 Author Share Posted August 26, 2018 Several thousand will motivate me to learn myself! I cant believe it would cost that much for diagnostics and the few things you mentioned. But this is california. I guess I should start with an oil change locally and then go from there. Quote Link to post Share on other sites
Gulfstream Greg Posted August 26, 2018 Share Posted August 26, 2018 Bobby's Pit Stop in Santa Cruz replaced our starter (89 V6) using their lift. They have done other work also, always great service. I tried doing the starter myself crawling under. Gave up, took it to them! Quote Link to post Share on other sites
neubie Posted August 26, 2018 Author Share Posted August 26, 2018 thanks Greg, will look for them if/when serious work is needed. Quote Link to post Share on other sites
neubie Posted September 5, 2018 Author Share Posted September 5, 2018 (edited) Drove around for a while until I located shops with higher bays. Fortunately one of the no wait jiffy lubes had tall bays. Car has new fluids. They fidgeted with the oil filter for a bit before managing to get it off. Hopefully nothing stripped. Cant say I could tell if there was anything in the oil but it sure didnt look too bad from a distance. There is a fair bit of condensation from the tail pipe, so I have been worried about the engine leaving me stranded. None of the telltale signs appeared in the fluids so I am hoping to drive a few hundred miles and test out drivability. Cant say the same about shocks and brakes. They will need a looking into. Dont inspire a lot of confidence in limited driving. Lesson learned: Learn the height of the truck well. Everything including tree branches, low bridges, and low bays are real and often unexpected enemies. On the positive side, havent scraped my bottom in a while. Edited September 5, 2018 by neubie Quote Link to post Share on other sites
