Sunrader Coach Door Repair or Replace
Captain JJ
 Share
First, thanks to all who helped me with my TV cable question. Got the part from Toyota, had a transmission shop replace and service the trans. Runs like a new one now.
I found that my entry door is rotted at least at the bottom, perhaps farther up.
Options are to rebuild it or find a replacement. Has anyone done a rebuild?
I've looked on line for replacement doors, but can't find my size. Most RV doors seem to be 24 inch wide.
My door is 21 inches wide and 63 inches high. Radius corners at top.Door.thumb.jpg.23193ffdd3ef4e70a946138281176838.jpg
Thanks in advance for any help.
JJ
There are rebuildable I have done several you will need some tools like a table saw I use pressure treated ripped to size (it's not standard sizes) not sure how they made the curve probably plywood but it can't be that difficult there is not much to them. Generally there is nothing more than a perimeter frame, aluminum sheet and styrofoam core.
 Share
