cruisecontrol Posted June 23, 2018 Share Posted June 23, 2018 Hi I posted this on my own profile/status...probably the wrong place. i need to replace 5 light covers in my 1990 Toyota slumber queen: they have no identifying mark or number on the, but I’m discovering they are smaller than every other cover I have found on amazon, eBay, rv supply stores. They are 4 and a half inches square, give or take, they are flexible with 2 ‘lips’ that allow them to pop in and out. If anyone has the same and knows where I can get them I would love to know? photos below Quote Link to comment Share on other sites More sharing options...
stayingretired Posted June 23, 2018 Share Posted June 23, 2018 I had the best luck on fleabay. While my measurements did not match perfectly, I was able to pop them in. The lens has no marking, but the lamp itself may. Try there perhaps? It looks similar to the listings for Progressive Dynamics lens here: https://www.ebay.com/itm/Progressive-Dynamics-Replacement-Lens-for-Single-Interior-Dome-Light-for-RV/392068683484?epid=1522687819&hash=item5b491d56dc:g:kAgAAOSweW5VYjea ...which is too big at 5x5 inches. I found the make/model on the body of the lamp itself and searched for that one in particular. Quote Link to comment Share on other sites More sharing options...
cruisecontrol Posted June 23, 2018 Author Share Posted June 23, 2018 Thank you, stayingretired! Yes I thought the progressive dynamics ones would work too, so I ordered them, and had to return.. as soon as I pick her up from the shop where she’s getting a new fridge, ?, and a few other things, I will do as you advise, which I should have done in the first place... Quote Link to comment Share on other sites More sharing options...
Ctgriffi Posted June 25, 2018 Share Posted June 25, 2018 In my experience, 12V light fixtures are cheap to buy and very easy to replace—that's what I did with all of mine in the 91 Warrior. Old, yellow-ing plastic stuff just doesn't do much for me... but maybe yours have aged better. I had good results with the double and single versions of these: http://a.co/0qFzjma Quote Link to comment Share on other sites More sharing options...
cruisecontrol Posted June 25, 2018 Author Share Posted June 25, 2018 Thanks so much for your suggestion, Ctgriffi, but they don’t come in the size I need. 4 and a half inches square....I have 5 missing? Quote Link to comment Share on other sites More sharing options...
linda s Posted June 25, 2018 Share Posted June 25, 2018 45 minutes ago, cruisecontrol said: Thanks so much for your suggestion, Ctgriffi, but they don’t come in the size I need. 4 and a half inches square....I have 5 missing? I think he's suggesting you replace the entire unit because they are not that expensive. Linda S Quote Link to comment Share on other sites More sharing options...
Ctgriffi Posted June 25, 2018 Share Posted June 25, 2018 2 hours ago, linda s said: I think he's suggesting you replace the entire unit because they are not that expensive. Linda S Exactamundo (Thanks, L) Quote Link to comment Share on other sites More sharing options...
stayingretired Posted June 26, 2018 Share Posted June 26, 2018 There are 12V LED strips available on fleabay for under $3/each. My one replacement lens cost me upwards of $8. Unless you are doing high-end photography or have specific issues besides not tripping over stuff, you may wish to replace the lamps themselves and get one 'nice' full-spectrum incandescent 12V lamp for reading. Unless you want to spend money, in which case I will sell you all of mine at a really good price. Quote Link to comment Share on other sites More sharing options...
Allan Posted June 29, 2018 Share Posted June 29, 2018 (edited) I replaced my hot to the touch incandescent bulbs with cool, flat LEDs. As the LEDs produced relatively little heat I was able to replace the broken convex light covers with flat translucent plastic material I just cut to the size of the fixture. The reason the original covers were convex was to keep them away from the hot bulbs so they wouldn't melt. I still have a couple of original covers but I was unable to source replacements for the broken ones. This was fast, cheap, and easy. I did this five years ago to replace all the broken covers . Edited June 29, 2018 by Allan Added more text. Quote Link to comment Share on other sites More sharing options...
cruisecontrol Posted July 2, 2018 Author Share Posted July 2, 2018 Thank you all! I’m going to look into the strips and making replacements myself?? Quote Link to comment Share on other sites More sharing options...
cruisecontrol Posted July 10, 2018 Author Share Posted July 10, 2018 Update?, after diligently searching and great suggestions from others, I found 6 lens replacement at westcoastrvrecyclers in centralia Washington. Sent photos, and the guy there, (Ron) was super helpful. $1 each and shipped in 2 days! Quote Link to comment Share on other sites More sharing options...
