Eric Day Posted May 4, 2018 Share Posted May 4, 2018 My factory Kohler 2.5CMZ generator has been acting up...I believe the carb is gummed up. I bought a new one, and now on closer inspection it seems like the entire generator might have to be removed to get the carb out...hope I'm wrong. Anyone have experience removing their carb? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted May 4, 2018 Share Posted May 4, 2018 Can't help you with the carb removal question, but here's a copy of the Manual (if you don't already have a copy). Kohler_p5418.pdf Quote Link to comment Share on other sites More sharing options...
Maineah Posted May 6, 2018 Share Posted May 6, 2018 On 5/4/2018 at 1:58 PM, Eric Day said: My factory Kohler 2.5CMZ generator has been acting up...I believe the carb is gummed up. I bought a new one, and now on closer inspection it seems like the entire generator might have to be removed to get the carb out...hope I'm wrong. Anyone have experience removing their carb? Having no ideal how it's mounted in the camper you maybe able to remove the carb and manifold as one unit I'm figuring getting to the bolt on the engine side of the carb is going to be a treat from the picture in the manual. Quote Link to comment Share on other sites More sharing options...
danny dan Posted May 12, 2018 Share Posted May 12, 2018 On 5/4/2018 at 1:58 PM, Eric Day said: My factory Kohler 2.5CMZ generator has been acting up...I believe the carb is gummed up. I bought a new one, and now on closer inspection it seems like the entire generator might have to be removed to get the carb out...hope I'm wrong. Anyone have experience removing their carb? You should be able to just unbolt the intake manifold/carb/airbox as an assembly and pull it out. I believe you have the same setup as my Itasca. Quote Link to comment Share on other sites More sharing options...
brucerhahn Posted June 27, 2018 Share Posted June 27, 2018 Hello Eric, Can you point me to where you found the carb? I'm having the same gummed up problem with my Kohler 2.5CMZ. Thanks Bruce Quote Link to comment Share on other sites More sharing options...
brucerhahn Posted June 28, 2018 Share Posted June 28, 2018 Anyone have a source for this 2.5cmz-21-rv carb? thanks Quote Link to comment Share on other sites More sharing options...
linda s Posted June 29, 2018 Share Posted June 29, 2018 The best idea I can think of is to find a tecumsah carb that will fit. If you can find a local generator repair place they should know if it will. Linda S Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted June 29, 2018 Share Posted June 29, 2018 do you need a part number? See attached pdf TP5143 2 AND 2.5 RV CMZ_parts.pdf Quote Link to comment Share on other sites More sharing options...
linda s Posted June 30, 2018 Share Posted June 30, 2018 Great post Dan. I saved it cause I have a Kohler too. I did think any parts were available anywhere for the Kohler RV generator but found the carb pretty quick with the parts PDF. https://www.colburnpower.com/kohler-part-a-228225-carburetor-incl-65-gasoline.html Linda S Quote Link to comment Share on other sites More sharing options...
brucerhahn Posted June 30, 2018 Share Posted June 30, 2018 Thank you both. I finally did find a rebuild kit, part# 228393 using the spec# 177111 Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted July 2, 2018 Share Posted July 2, 2018 here is the service manual too also a few tecumseh manuals... TP5148_2_AND_2.5_RV_CM_AND_CMZ_2.pdf TEcumseh_manual_692509.pdf tecumseh-troubleshooting.pdf TVM140-70328K_parts.pdf Quote Link to comment Share on other sites More sharing options...
