Hello,
We are the proud owners of a 1985 Sunrader with 54K on it. It is a great running vehicle with one exception. It will not start if it is not up to a full charge. If it has been sitting for a while and the battery only has 12.5 volts in it, then it just "clicks" when you turn the key. Sometimes if you hold the key in the start postion for 5 or 10 seconds, the starter will go, and turns over very quickly. Most vehicles, if the battery is down a bit, will crank slowly. This one just doesn't go. I have replaced the engine battery, and that seemed to help for a while, but it is back to its old tricks. Could it be something in the starter or ignition switch? Once started, the alternator show 14 volts, so I know it is charging OK, and once It has started for the day, it seems to be OK for the rest of the day. Any advice you can give me would be greatly appreciated. Camping season is upon us!!!
