Showing results for tags 'solar power'.
If you were starting over with the gutted interior of a 1982 Sunrader 18' what would you do with it? What would you put in it? What would your layout be like? (Existing layout is house door forward with rear dinette) What materials would you use to make everything? And how would you do everything so it is AS SIMPLE AS POSSIBLE? Here are my parameters... -Full time living and traveling for one human. -BATHROOM: I'm going to build a simple cheap "compost" toilet and I'll have a small sink. The entire bathroom must be waterproof so I can take showers and probably in the same location (behind the drivers seat) since the tank is there. I will install a small opening window with screen to air out the bathroom. -HOT WATER: I'm considering one of these two options: Install an instant on-demand propane hot water heater...or use a garden sprayer with a metal tank and a modified shower head that I can place directly on the stove top to heat the water and paint it with Rustoleum High Heat paint so I can heat it in the sun on hot days. I'll have a spot on the corner wall of the bathroom I can mount the garden sprayer for showering. -COOKING: Counter space to prepare stuff, Storage for eating/cooking utensils, large sink with manual foot pump, BIG fridge (7 cubic ft), 2 burner stove (probably a Coleman camp stove if I can figure out how to make cookies and pizza on a stove top). Drinking water will be in 1 gallon jugs. -WORKING: I need desk space to work and space for my 17" Macbook Pro with a 25" external monitor. -SLEEPING: I'll probably use the overhead for sleeping with a twin and put some light storage forward of that in plastic bins. -HEATING: I'll use one of those little portable propane heaters. (I think its called "Mr Buddy" or "Mr Heater") -BOONDOCKING: I will be stealth city camping as needed but plan on boondocking for extended periods of time so energy efficiency is key and preferably renewable. -FLOORING: If I can make the sub-floor smooth enough I'll probably install vinyl. If not, then probably laminate flooring. -WALLS & CEILING: Thin plywood panels painted with semi-gloss white that can be easily removed to access stuff behind (although I plan on having as little of the hard-to-access stuff as possible!). -INSULATION: Probably some closed-cell foam stuff from Home Depot. -CEILING FAN: Maybe a Fantastic Fan or equivalent?? -LIGHTING: LED and probably individually self-contained with their own little batteries so I don't have to run wires. -INTERNET: I'll use my cellphone as a hot spot when I can and install a multi-directional WIFI signal booster to sponge off of open networks. -MOVIES: I'll get one of those external hard drives with the built in wireless network and load it with a terrabyte of movies so I can watch movies with my iPad. -TV: I might have a UHF antenna to pick up local stations and watch that stuff on my computers external monitor. -FRONT CAB: I want to change out my front seats for something more comfortable that I can buy used on Craigslist. Does anyone know what other seats fit an 82 Toyota with minimal modifications required? -EXTERIOR: I'll probably use reflectors instead of the existing DC wired clearance lights. On the top I'll probably build a low profile aerodynamic lockable box to store surfboards in in with solar panels mounted on top of it. I'm going to spray the entire vehicle with almond Rustoleum paint (i.e. "The $50 paint job"). I've done countless camping trips all over and surf safari's into deep baja so I know how to poop in a hole and live animal style, but for full-time living thats not how I choose to live. So my plan is to have the creature comforts required for full-time living but make their systems as simple and as energy efficient as possible. Anywhooo, a lot of you have used your Toyota motorhomes a lot and have learned a few things along the way so I will greatly appreciate any of your ideas and input. Seriously - anything! :-) Thank you. Steve
- 14 replies
- sunrader
- energy efficient
