Showing results for tags 'single wheel'.
Hi folks. Been researching for some time and now am asking for some first hand advice if it is out there on single rear wheel axles. Mainly stability and hub strength. I have a 1982 Toyota Sunrader 18' that is slated for a 4WD conversion. Currently has a foolie. Considering a T100 or Tundra rear semi float for width and the stout diff, but it's still a semi float. Do you have experience with a single wheel rear axle and can comment on stability? How about lessons learned about the semi float hub on a single wheel or full float conversions? Maybe you didn't go the Toyota route but put Dana's in? Before I pull the trigger and drop a single wheel rear axle in I am looking for advice from those behind the wheel of similar rigs. FYI, I am a long time Toyota hobby mechanic but new to RV's. I am probably moving both cab and camper shell over to a 1984 long bed chassis. I have considered and read about full float theory, single spare convenience, diff strength, challenges with conversions to rear disc brakes. I am planning a light build but we all know how that goes. Thanks so much in advance!
- single wheel
- t100
