Showing results for tags 'shore power'.
I have this '85 New Horizons which has a circuit panel containing 3 circuit breakers. One of which trips when I plug into shore power. I do not know what ANY of the breakers do, except that one of the two remaining breakers that stay on control electric outlets and all 12 volt systems (lights, water pump, heater fan) kick over to the inverter (you can hear it switch when we plug in). We no longer have an Air Conditioner (removed by previous owner), so I can assume one breaker may have been for that. But the other breaker is unaccounted for. Any ideas? Is a schematic available? Also, we changed all 12 volt bulbs to LED. Since then, they only flicker when turn on while on shore power. They work fine off the battery. I'm thinking the problem is with the LED bulbs - not the system. Voltage at socket when on shore power measures 13.6 volts.
- circuit breaker
- shore power
Yesterday I finished the install of the Xantrex Freedom SW 2kw invert (yes 2kw is 2000 watts). http://www.xantrex.c...12v_newgen.aspx My 1.8kw Xantrex gave up the ghost so I stepped up to their newest model the Freedom SW. Talk about a MONSTER. It weighs 60 lbs. It is all digital including the 30 amp transfer switch which kicks over in microseconds if it detects a drop or brown out in the incoming AC current (either from shore power or a brown out from the generator). This one has a very sophisticated built in battery charger so I pulled my converter out completely since it would no longer be used. Of course..... Here is the requited eye candy for everyone The inverter next to the furnace (gives a good idea of the size of it) http://i586.photobuc...ter/sw_2k-1.jpg http://i586.photobuc...ter/sw_2k-6.jpg http://i586.photobuc...ter/sw_2k-7.jpg The unit has 2 cooling fans but I could not get it warm during testing even when running the microwave and TV continuously http://i586.photobuc...ter/sw_2k-2.jpg Because of the weight I did not want to mount it on the generator compartment so I built a shelf that is attached to the Surader's fiberglass shell for support. http://i586.photobuc...ter/sw_2k-4.jpg A few more pics (if you are not bored yert) Used a Moroso racing DC cutoff switch on the DC line http://i586.photobuc...ter/sw_2k-5.jpg This is the DC fuse for the I/O positive line http://i586.photobuc...ter/sw_2k-3.jpg I used Moroso racing DC firewall pass through to get the battery lines out of the enclosed battery compartment. This is a hole in the compartment with a sealed plug having battery post connections on each side so that I have a completely sealed battery compartment. The grey phone line is the battery monitor line from the charger/inverter. http://i586.photobuc...ter/sw_2k-8.jpg The remote control for the inverter will be in today then I can button it all up and move on to the next project Mike (AKA - turtle) 1991 V-6 auto 18' Sunrader, Downey Racing air intake, JET Performance ECU re-programing, Prothane poly suspension bushings, Firestone Ride Rite Air suspension, Downey Racing rear suspension, 4.56:1 Rear end gears, Bilstein shocks, Xantrex Freedom SW 2 kw inverter, Onan 2.8 kw genset,
