Showing results for tags 'seals'.
I have a rear window leak. I've heard all I need to do is pull apart the rear window, clean around put in some butyl tape and maybe add some extra silicone, and put it back together. I also have an overcab leak, it seems to be lined up with the seam over my overcab, so I guess I can pull off the bar that goes over it, clean it up, apply some butyl tape there, and put it back on? Is Dicor still the best thing to pour onto my roof? The thing is, my entire toyhome seems to have tape that uh... is probably well over 10 years old. Should I just take my toy to someone and have them re-seal the whole thing? Or is it better to not mess with an area until it leaks? If I'm thinking about mounting solar cells to my roof, should I seal before I do that, after, or both? If I should take it to someone, who? I'm in the mid-atlantic near DC right now.
Greetings, I have a 1986 Sunrader, and need to replace the seals on the two front upper windows. Where would I go to get seals. Thanks much.
I've read everything I can find on the rear axle issues, but can't find what I'm looking for. I have a 1983 Sunrader, and it as the upgraded 6 lug axle, but I can't find any information on it. Is it a later model Toyota axle? Is it from a different manufacturer? Did Gardner Pacific replace it with something completely different? Is it a 1 ton or a 3/4? What size cylinder and seals does it take? We've tried 3 different sets, but nothing seems to fit. Any help greatly appreciated. Ron
