Showing results for tags 'restoration'.
Hi all, It's so exciting 😃! My wife and I are completely new Toyota RV Owners since just yesterday I bought a 1991 Odyssey Americana in central Pennsylvania. It is the Fargo 21.5' configuration and is in fairly good condition overall, low mileage (68K miles) and seems to run fine. I just drove it about 60 miles yesterday to pay a surprise visit to my parents and tomorrow I'll begin the 800 mile journey home to Wisconsin. We are very much looking forward to hitting the road with it. When my grandparents retired in the early 1960s they bought a "Scottie" camper and drove across the country with it. Now that we're looking at possible retirement, perhaps we'll follow their tire tracks 😎. While good overall condition, I'm reminded that this camper is 28 years old, no spring chicken, and it will need some love and attention. I figure one "RV-Years" is about 2.5 people years. So my "28 year old" RV is about what I'll be when I'm 70, which isn't all that far off. I'm posting some photos and hope to learn from the collective wisdom that I've discovered in this forum. Here are some observations and questions: We will probably keep the interior configuration, at least for now, and right now everything works (with possible exception of the water heater). We do want to rid the camper of the 80's carpet-on-everything theme. We will probably do laminate on the floor, not sure what to do on the ceiling. We're not sure what we'll find when we remove the carpeting. Any suggestions, especially for the ceiling? We want to give the exterior a major make-over, both functional (leaks????) and cosmetic (looks 28 years old). The first step I believe is to get remove the original stripes that were adhesive decals, but I want to do this without damaging the fiberglass underneath. In some areas, as you can see from the photos, the decals are already gone, other areas have a little remaining adhesive, other areas have relatively pristine decals still adhered. What method/solvents/etc. are recommended for removing these from fiberglass without leaving worse marks / damage? I was told by the original owner that the front window had leaked, but he repaired it with some super-sticky tape, perhaps Peel & Seal. Also, the window, which is plastic, is so weathered it's opaque. Or maybe it was originally that way. Either way, I'd like to see out of it, clear as glass. Two questions: (a) Are replacement windows available? Where? (b) How can I effectively re-seal this so I can remove the tape and not have leaks? The roof may have leaked at one point. I've read that the Americana has a rubber roof, but I can't really tell because a previous owner coated the roof with the type of material used as a truck bed liner, and the recent owner added a couple waterproof panels and some sealing tape. I don't see any present leaks, but I don't want to keep adding bandaids, I'd like to restore it to an original condition. Thoughts? Anyone tackle this on an Odyssey Americana before? The roof also apparently sagged / bowed in a little and left standing water on top. The previous owner reduced this by adding an exterior beam brace - you can see it in the middle on the last photo - to pull the roof up in the center to reduce pooling of water. Does anyone have tips on restoring the correct arch of the roof in a more long-term way, without external bracing? Thanks to all of you for your thoughts on this little restoration project. Looking through the Forum archives I see many of you have taken on much bigger tasks. This is not so daunting, but I'd like to get to a good start, get our new home-on-wheels fixed up, then hit the road. Scott
- fiberglass
- restoration
So im into for less than 2k, got it from 3rd owner, only 50400 miles, replaced belts and other wearables and it's running great, the issue is water damage, the roof and paneling under fiberglass is done for, I live in it full time atm due to losing previous RV in a fire in California but I have access to a garage and tools with a cot and plenty of help for when I get to replacing the cab-over, with that being said, I'm going to have to gut and replace all insulation and 2by2, should I start with the rear or front, I'd like to get my bed situated first so I can just stay in it while finishing the rear, if it's smarter to just room up for a month and just do it all at once starting with the biggest problem areas? Is it possible to replace rot with new, section by section after I tear out the appliances and shower/toilet/sink after taking care of the cab-over area? The floors are all still super solid and other than the rot and little replacements like skylight domes and minor things it's a great little rig. I need opinions and just what you guys think you would approach as far as starting restoration and if I can live in it while I do, Thanks y'all https://drive.google.com/folderview?id=11fvXcf0pDGbiffQBSSZeRPp9Fv89jYjK
Hey Everyone, So I'm replacing my roof, and looking for some advice on a material... (I have a '78 Dolphin Micro Mini, so weight is even more important than normal.) I feel like ¼" luan is the ubiquitous workhorse, so it's what most people recommend. However, while at Home Depot, I found some ⅛" hardboard that feels like it would be lighter (and cheaper). Since it'll be covered in EPDM, and my roof doesn't need to be incredibly load-bearing, is there any reason why I shouldn't go with that, instead? It's half the price of the luan, and has to be lighter than ¼" luan, I would think. One obvious downside is that because it's thinner than the luan, it would also be just a little more difficult to walk on my roof, having to be very careful not to cause distress, as it would most certainly be more prone to breakage than the ¼" luan. Anyone have an opinion to share? Should I just stick with what everyone uses? Or has anyone used ⅛" hardboard before?
- 5 replies
- roof
- restoration
Well, the project begins. Probably should have started when it would be warm a little longer but all this last week we've been pulling stuff out. So far we've taken 360 lbs worth to the dump with easily twice that much weight in the garage in more trash, appliances, and four deep cycle batteries. Not entirely sure where we're going with this but we've decided we'd like to start with a clean slate. From the pictures, you can see I've had a little help. I've gotten some more done but don't have pictures yet. We've got a bit of snow that's slowed the process a bit. I pulled the shower/bathroom stall out in one piece through the back window opening. I'm going to end up cutting it up to use to fill old window/accessory holes we're not going to use anymore. The tear down should go relatively quickly. It's the build back that's going to take forever.
- 170 replies
- restoration
- remodel
