Showing results for tags 'power converter'.
Hello! I recently purchased a 21' 1986 Toyota Crossman, which my partner and I dubbed "Little Buddy." Little Buddy has treated us well thus far but unlike the other RV I have owned (a Four Winds Hurricane) the coach power does not work unless plugged into shore power via the pigtail. A post made to this forum by Jake_Womack earlier this year described a similar issue, which other forum readers suggested was caused by a malfunctioning relay or switch. Could that be the culprit in my case as well? Do I need a new switching supply? The Power Inverter in Little Buddy is: Series: 6300 A Model: 6336 My knowledge with electrical systems is slight, so your input is most welcomed. Thanks in advance! And in case it impacts the responses to the above issue, we also plan to: - add a generator (Honda - it'll fit well in the vented external storage area behind the drivers seat) - swap out the current coach battery with an AGM (Optima) - add an inverter
- 15 replies
- crossman
- electrical
