Showing results for tags 'headlights'.
I just bought a 1992 Dolphin and have quite a few projects in my future. I have some marker lights that need replacement right away, so I figure instead of replacing with the same lights, I should think about upgrading to LED. I'm trying to be cost efficient and not invest in anything I want to replace later, even though the cost is minimal. My question is, if I were to swap out all of the marker lights in the rear with LED instead, is there anything I would need to do other than simply connect the wires and attach? Eventually, I would want to replace the headlamps and interior lights too. I have read that the headlights would require a new wiring harness and that for an RV, LED lights should have a voltage regulator. I'm not sure what to look for or avoid, or if swapping even the marker lights to LED could involve more than I realize. I'm a newbie, both to owning an RV and also doing this work, so I would appreciate input that explains this in simple terms. Links to low cost lights also appreciated. Thanks!
