Showing results for tags 'gear oil'.
Right around the same time Badgerbear posted about this same issue, I started noticing it on my driver's side rear axle: wet/dirty hub, strong smell of gear oil. Finally got time to start digging into the problem tonight (and, btw, I'm super-thankful for the great tips and photos that were posted in BB's earlier thread!). Once I got the darn cone washers out, I got a good look inside the hub, and everything is nasty/filthy in there! Can't wait to get that all cleaned up, looking good, with new grease. Anyway, it didn't take long to see what was causing the leak... the outer seal is totally wonky and off-center, as you can see in this photo (sorry, working outside in the dark; poor lighting). When I bought this Toy about 2 years ago, the PO told me that he had just had the rear brakes serviced to the tune of several hundred $$$, and I'm guessing that somebody didn't get that outer seal installed correctly (or, could it have moved somehow?). Fortunately, the inner seal was working great and the inside brake area was completely dry; everything in really good shape there. So, I'm going to replace the damaged seal, and check the bearings and repack 'em. I do have a few questions about all this, for the gurus: I'll need to pull the inner seal out to remove the inboard bearing for inspection/repacking, so... should I probably plan on replacing that seal too, given that it could get torn up during extraction? There seemed to be some sort of paper gasket material visible around the hub (see in above photo) once I pulled the axle. I haven't heard anybody mention a gasket like that—would black RTV sealant work as a replacement? Recommendations? Not really a question, but... I don't know how much fluid has been lost, so I probably better count on topping off the differential when I'm done. I banged up one of the six hub studs (see below) and put a nice, little curve in it, while trying to get a really stubborn cone washer loose. Will I need to order this from Toyota or is there another good source? (Links always appreciated!) Thanks for looking, guys/gals. Appreciate the help!
89' Dolphin V6 64,000 miles So I was noticing the smell of gear oil when walking beside the camper on the drivers side, but didn't see anything obvious. I took her for a little trip and now I have a substantial amount of grease/ gear oil leaking from the rear drivers side hub that has coated my rims with grease and there is a puddle of grease sitting in the bottom of the rim and running out onto the ground!! I've never seem anything like this and am assuming that it is some kind of rubber seal that has deteriorated? It would be so great if someone could help me figure out what's going on here and how to fix it. Thanks so much!
