Showing results for tags 'fix'.
Hi, thank goodness for this site! My husband I and recently purchased a 1991 Toyota Dolphin. We think we got a good deal at $1000 and 80,000 miles. Mechanically we think she.s in decent shape, but needs some fixing up. Our concern is with the seemingly entire rotten wood frame of the living quarters. So far we pulled out the couch and eating area and pulled out the overhead cabinets and the whole left wall (drivers side) is rotten. The roof seems to be in OK condition and the sleeping area needs total repair. We plan to finish gutting it and rearrange the space with our own much lighter setup. My questions are - where do we start reframing? What materials are ideal to use and do we have to remove the fiber glass or can we rebuild from the inside? Did we get a good deal? Any thoughts or suggestions would be really appreciated
- 11 replies
Though the PO did a good job of Dicoring all the seams, I didn't believe him when he said "You won't have to worry about any leaks for years". I noticed that back by the propane tank on the dogleg of the Dolphin, the siding had pulled away from the channel and the Dicor just wasn't going to hold it together. So using a technique that I developed while living in an old trailer, I tried this fix. A narrow strip of aluminum foil to initially bridge the gap, several pieces of Gorilla Tape to give it some body, and topped off with aluminum foil tape. I added some extra pieces of aluminum foil tape down in the channels to make sure it was sealed. If you ever tried to get this aluminum foil tape off, well it's pretty danged sticky. I figured if you got a leak, you got to fix it now. Worry about doing it right later. I added some dots of reflective tape to gussy it up a bit. We'll see how long it lasts.
