Showing results for tags 'diy repair'.
  1. Hello, I'm looking for some advice on how to remove the metal step under the cabin door. The bolt just spins when you turn the nut. I don't know where the top of the bolts are or if you can get to them without taking things apart.
  2. Hi all! I am tackling the water damage from a pipe vent leak in the Sunrader next week. Any advice on this is appreciated. Damage is in the cabinet above the fridge. I used silicone as a temporary fix on the roof, leaks have stopped. The goal is to clean the roof and reseal all points of entry once the interior water damage is repaired. Not interested in a full on demo / rebuild of my Sunrader interior; simply want to address the damage and mold in this one spot. Thanks guys!
