Showing results for tags 'cooling'.
Found 3 results
  1. My thermostat is occasionally sticking, so I'd like to replace it. Easy enough, except the bolts on the housing seem to be seized. Don't want to snap or strip them, any tips? Tried searching past threads but didn't find anything. 1985 Sunrader, 4cyl 22RE. Thanks!
  2. I have a 1990 Warrior with a Norcold fridge. I cleaned out the whole burner area and replaced the burner and thereby the gas orifice. I don't get anything but a small flame, blue, and it doesn't cool the fridge. It cools very well electrically so I know it's not a coolant problem. Gas pressure is around 7 at the gauge. Is that high enough and if not how can I increase it? If the problem is something else any ideas on diagnosing it? I rapped on the flue and blew the whole area out with air but no help. I'm sure that if I had a good enough flame I'd have the cooling I need when not onshore. Any help much appreciated!
  3. I just replaced my worn out fan clutch and in the process managed to tear up my old, brittle, cracked fan shroud. In searching for a replacement, I haven't been able to find one for a 1987 w/ an automatic transmission. Most of the ones on ebay say "manual transmission only. Does anyone know if there really is a difference? And, if so, do you perhaps have a source for the correct one for the automatic?
