Showing results for tags 'converter upgrade?'.
  1. Hello, I've seen some good discussions on here regarding Converter issues. I was hoping for help... I am the owner of a 1986 Sunland Express with a solar system installed. The solar isn't the problem. Recently the Converter started making a bit of a buzzing noise. And certain wires worked to light up lights or other electronics and certain ones don't anymore, like my water pump. I've gone through the fuses and don't as much as my limited mind can do. I think I need to replace the converter. Anyone know of the proper converter replacement for the Underwriters Laboratory Model 6346 Converter and Battery Charger? I saw this link https://www.campingworld.com/wfco-45-amp-universal-replacement-kit-58357.html On another discussion regarding converters. Any links of model names would help me out a ton. Thanks, Sam
  2. I have an '87 Sunrader. My last motor home was a 2005 Winnebago View and I swapped out the converter for an "intelicharger" converter. I found that with the original that my batteries, 2 six volt deep cycle, sulfated during the winter and I had to replace them, two years in a row. They were very expensive Trojans. I found the "intelicharger" pulsed 14 amps into the batteries occasionally preventing sulfate build up. No more problems and I was able to use cheap Costco golf cart batteries. Has anyone with a Sunrader replaced their converter with a later model? Thanks, Life is good in the slow lane! Iflyfish
