Showing results for tags 'clutch'.
Found 4 results
  1. Greetings from the FNG, Has anyone had to address a throwout bearing on one of the 4 speed trannys yet? Mine started making that infamous knocking noise while out of gear however it subsides while in gear, under load. Any and all comments welcome, thanks everyone! Happy travels, BD
  2. Driving along a country rode and suddenly she’s not in gear. Clutch feels ok, can move gearshift all the way around, but not going into any gear so I had to stop. Looking for advice on what it might be and also any recommendations for a good mechanic near North Kingston Rhode Island. Thanks!
  3. I'm thinking of installing a new clutch kit in my 1985 Sunrader, 4 cyl 4-speed manual. I don't think it's ever had any tranny work done, so it's likely got whatever tranny they normally came with. Would it just take a standard 1985 toyota pickup kit or was a different tranny used due to the weight of the rig? Any recommendations as far as manufacturers? And, since the rig weighs in at around 6300# fully loaded, is a heavy duty kit recommended? Thanks for any advice from those better versed than me.
  4. I have an '88 Itasca with a 22r and a 4 speed manual trans. I need to replace the clutch as it is beginning to slip and there is no adjustment as it is hydraulic. Do I need to get a special heavier duty clutch for a 1 ton or will one slated for a pickup work? Also, any good links out there for r&r instructions for the clutch? Thanks. gj
