I Fought The Tank And Won 1985 Dolphin
mechy411
It has sit in a field for the last eight years was not getting fuel. I ended breaking a outlet tube from where fuel pump sends out. So now I need a new pump hanger $89.00 advance. When I got the tank out It sounded like gravel inside. It was bad shook a chain it forever then a acid bath now getting better. The fuel level sensor also seems to be bad I have got to move but it shows as a open circuit on the ohm meter. another $38.00
One question what is the cake pan in the bottom for? it is 8x8" maybe 3" high with a tube going from inside
post-6299-0-31741800-1440287894_thumb.jp
post-6299-0-35181500-1440287914_thumb.jp
post-6299-0-30003400-1440288669_thumb.jp
The cake tin is a fuel baffle. It keeps the pump inlet covered when the fuel level is low and your going around corners and the fuel is sloshing back and forth
