Airbags for a 1982 Toyota Dolphin - Impossible to find?
#1
Posted 30 July 2010 - 12:15 PM
#2
Posted 30 July 2010 - 01:42 PM
Another solution would be to get your existing springs re-arched and perhaps a leaf or two added.
#4
Posted 30 July 2010 - 03:07 PM
#5
Posted 30 July 2010 - 03:34 PM
Does your home have the 1-Tonne rear axle and springs installed? I wonder if you couldn't just use the air spring kit for the '87 pickup. Remember (I think) that the 1-Tonne dualie didn't exist in '82. If the frame design didn't change between '82 and '87, then you've basically got an '87, at least as far as the rear suspension is concerned.
#6
Posted 30 July 2010 - 05:22 PM
I do have the bigger, full floating axle. That's something to think about. I'll photograph it. Thanks.
#7
Posted 31 July 2010 - 08:44 AM
#8
Posted 31 July 2010 - 11:55 AM
I'm guessing the listing only goes back to 1986 because that's the year that they started leaving the factory with the 1-Tonne axle fitted. Before that, they went out the door with the 5 lug. But, of course, many were subsequently retrofitted after the recall.
#9
Posted 18 August 2010 - 08:54 PM
#10
Posted 20 August 2010 - 10:51 AM
#11
Posted 20 August 2010 - 12:11 PM
Packoderm, on 30 July 2010 - 04:15 PM, said:
You might try and see if these will work.
http://cgi.ebay.com/...=item4cecb6e254
I had a hard time finding bags for my 91 Warrior. They are apparently not making them anymore and this fellow on E-bay was the only guy I could find them from.
#13
Posted Yesterday, 10:09 AM
Those will work. Just installed them on an 87, and they fit my 82 as well. They are available through a variety of places. Including Ebay, Amazon, SuspensionConnection, Jegs , and the list goes on.
- ← Previous Topic
- Engines - Transmissions - Drive Train - Suspension - Chassis - Steering - Exhaust - Tires - Etc
- Next Topic →
Sign In »
Register Now!
Help
