markwilliam1 Posted April 24, 2017 Share Posted April 24, 2017 When I got Grannie last year she had sat inside for 7 years. Only has 36K miles. Â I had to replace almost everything rubber in the engine. So I started her up Friday to run awhile and later while running I noticed a large wet area under the engine. Thought it was water but was gas! A ruptured fuel line that was covered with thick foam located by the charcoal canister. Didn't know that was a fuel line. The one hose I didn't replace! Gas spraying Everywhere. I'm blessed it didn't catch fire or happened while driving necessitating an expensive tow! My advice is to replace Everything that you can in these old engines and mileage doesn't matter. Also carry a fire extinguisher! Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 24, 2017 Share Posted April 24, 2017 AFAIK, the charcoal canister should only see fuel/gas vapor. So a bad line should not lead to a puddle of gas on the floor. Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted April 24, 2017 Author Share Posted April 24, 2017 Not a clear post I guess. The ruptured gas line was close to the charcoal canister not connected to it. Thanks Derek! Quote Link to comment Share on other sites More sharing options...
