Filon damage repair input please
vrocrider
I have a small area in the cab over near the roof that is damaged. Roughly 4" x 10" from the corner seam over to the center. The filon in this area has no wood backing and is laid over foam.
My plan is to cut damaged filon so I have straight lines. Remove any loose foam. I'll insert epoxy and fiberglass cloth just under the Filon surface and fill any voids under cloth with spray foam from a can. I'll trace opening I have created and cut a new piece of Filon to fit in hole supported by fiberglass cloth. I'll epoxy in new Filon.
Does this sound like a good plan? Suggestions? I've done some body work before but no fiberglass work.
Thanks.
