Anthony lawler Posted April 18, 2017 Share Posted April 18, 2017 I had power from the rv battery, then I ran everything plugged into shore power. I unplugged shore power and now have no power going to the breaker for outlets or the air conditioner. I started the engine, still now power. Is there an in line fuse from the battery to the electric panel hiding somewhere ? Quote Link to comment Share on other sites More sharing options...
fred heath Posted April 18, 2017 Share Posted April 18, 2017 You have two different electrical systems. Anything 120 volt must have shore power or a generator. Anything 12volt is run from your coach battery. Quote Link to comment Share on other sites More sharing options...
Anthony lawler Posted April 18, 2017 Author Share Posted April 18, 2017 I still have no power with the truck running Quote Link to comment Share on other sites More sharing options...
fred heath Posted April 18, 2017 Share Posted April 18, 2017 You have 12 volt dc with the truck running. Your A/C and any house outlets need 120 volt ac to run. Your truck will not produce 120 volts ac. They are two completely different systems. Quote Link to comment Share on other sites More sharing options...
Anthony lawler Posted April 18, 2017 Author Share Posted April 18, 2017 Ok, thanks for the information. Do you know anyone or where I could get an operators manual Quote Link to comment Share on other sites More sharing options...
Anthony lawler Posted April 18, 2017 Author Share Posted April 18, 2017 I have a 1989 toyota dolphin 6cyl Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 18, 2017 Share Posted April 18, 2017 If anything, a 1989 manual would have less info than 1993. 1993_Dolphin_Owners_Manual.pdf Quote Link to comment Share on other sites More sharing options...
Anthony lawler Posted April 18, 2017 Author Share Posted April 18, 2017 Thank you very much Quote Link to comment Share on other sites More sharing options...
