vrocrider Posted April 8, 2017 Share Posted April 8, 2017 (edited) Suggestions on what glue to use on more than spot repairs? Seems like I saw a post for West Marine epoxy but can't find it now. Going to replace the wood in the overhang. Also, what to use to clean backing of fiberglass? Thanks. Edited April 8, 2017 by vrocrider Quote Link to comment Share on other sites More sharing options...
hunkaman Posted April 8, 2017 Share Posted April 8, 2017 there are many adhesive choices. really dependent upon application and materials you are bonding. some suggestions could be: heavy duty construction adhesive (liquid nails), gorilla glue, 2 part epoxy's, silicone adhesive, professional wood workers glue. for cleaning the fiberglass ? again, depending on what you are bonding the fiberglas to, if the bonding surface is smooth / shiny, you may want to "rough it up", maybe with a 3m scotch pad, or sand paper, to give the glue increased bonding strength. hope this helps. joe from dover. Quote Link to comment Share on other sites More sharing options...
