Sunrader cab-over window
keith Zielke
Wrap around windows are available from Advantage RV in Napa Ca.
https://www.yelp.com/biz/advantage-rv-center-napa
They cost a little less than 300 bucks but he doesn't sell the seal. Is yours bad. Most people reuse them unless they are damaged. I have with fine results. Not so fine results with some that was clearly worn.
Replacement seal can be found online. Google locking weather strip and must know thickness of window and camper shell.
In the mean time to seal crack I love Shoe Goo. Works on everything as far as I can tell but keep it off your seal rubber if you want to reuse it
Really nice folks at Advantage RV!  Just got off the phone with them and have started the process of replacing my cab-over windows.  THANK YOU LINDA!
